Good A/F ratio for H23
Old Apr 13, 2005 | 05:29 PM
Ziggymidget5's Avatar
Default Good A/F ratio for H23
I know that the only way to make power is to tune a car properly on a dyno, but just from experience, what is APPROXIMATELY the optimal A/F ratio for a H23 engine with stage 1 cams and bolt ons? Is this about the same for any engine? Any other useful info is welcome, thanks.
Old Apr 13, 2005 | 06:32 PM
mgags7's Avatar
you should check out the "how to tune a car" section on importbuilders.com
you will see all you need there....
Old Apr 13, 2005 | 09:02 PM
Eddiebx's Avatar
for NA u generally wanna sit around 13-13.5:1 at wot. but theres no magic number to set it to, just see what makes power and stick with that
Old Apr 13, 2005 | 09:21 PM
homesauce's Avatar
Default Re: (Eddiebx)
Champaign IL? That's where im located at. Hit me up on aim: h0me5auce
Anyways, the stoichiometric A/F ratio is set at around 14.7. The ideal power is made a little bit richer than stoich. It doesn't matter what mods you have 14.7 is stoich, but in different cases of forced induction you need it richer.
Lazy Butt ALex
Apr 4, 2024 10:47 AM
Neonxiii
17
Nov 30, 2006 06:52 PM
HondaVTEC1993
Oct 9, 2005 07:11 PM
HondaH22A
Sep 13, 2005 03:22 PM
PhazedSI
Apr 26, 2004 11:36 AM
