Advice: What tires are worth purchasing...
Old Apr 13, 2005 | 04:13 PM
Top-Fuel's Avatar
Default Advice: What tires are worth purchasing...
Okay I have a 97 EK Hatch and I'm looking for some new tires just for summer thats going on my "WORK RSZ-R 15x7 +44 (Gunmetal)" rims. Right now i'm running stock engine but plan on getting a B18C5 Type-R with turbo, but thats later on. So i'm basically just trying to get all my suspensions done on my car first before I start purchasing the engine.
So if anyone can give me some advice on the type of tires to purchase and why, would be greatly appreciated.
Old Apr 13, 2005 | 04:25 PM
Kyles ej1's Avatar
Default Re: Advice: What tires are worth purchasing... (Top-Fuel)
man i just bought some falken ziex's for $38. i would reccomend those for dd cuz they are so cheap and ride nice
Old Apr 13, 2005 | 04:47 PM
Top-Fuel's Avatar
Default Re: Advice: What tires are worth purchasing... (ineedaswap)
thanks but i'm i dont' mind spending abit on the tires...
Old Apr 16, 2005 | 10:51 AM
Top-Fuel's Avatar
more idea's needed!
Old Apr 16, 2005 | 11:01 AM
Lmgrcivic's Avatar
get some toyo's or some BFG's if you dont mind spending the money
Old Apr 16, 2005 | 11:02 AM
sLoWrAcEr's Avatar
Default Re: Advice: What tires are worth purchasing... (Lmgrcivic)
azenis....get the new model!
Old Apr 16, 2005 | 11:06 AM
skip.two's Avatar
i like Toyo T1-S
you should try Searching "tires"
Recent:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">» Search Results
Your search for tires returned 199 results.</TD></TR></TABLE>
Archived:
Your search for tires returned 788 results.</TD></TR></TABLE>
Old Apr 16, 2005 | 11:14 AM
SASIR2's Avatar
Default Re: Advice: What tires are worth purchasing... (jL iLLuZiOnz 9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 &raquo;</TD></TR><TR><TD CLASS="quote">i like Toyo T1-S</TD></TR></TABLE> Have them on my R and they're great. I also like the Yokohama ES 100's, have those on my hatch. They're a little cheaper than the T1-S.
Old Apr 16, 2005 | 11:23 AM
garaged_Si's Avatar
man i just bought some falken ziex's for $38.&lt;&lt;&lt;------where do u get the falken for $38?
Old Apr 16, 2005 | 11:31 AM
Luserkid's Avatar
Default Re: Advice: What tires are worth purchasing... (SASIR2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SASIR2 &raquo;</TD></TR><TR><TD CLASS="quote"> Have them on my R and they're great. I also like the Yokohama ES 100's, have those on my hatch. They're a little cheaper than the T1-S. </TD></TR></TABLE>
I have some ES100s and i like them alot. But for performance type i just spin. Would you recommend the T1-S for street/drag tires or something else?
CUPRA_ROY's Avatar
falken is good. if you can get the f1 good year in this size its much betty.:0)
roy-israel
Old Apr 16, 2005 | 01:10 PM
sickity's Avatar
I got Pirelli P-zero nero on my 98 ex coupe, definitley recommend...
Old Apr 19, 2005 | 10:26 PM
Top-Fuel's Avatar
Default Re: (sickity)
Yeah i was looking into the Pirelli P-Zero Nero M&S because i've heard nothing but great rates on few sites. also read about the Yokohama avs es100 on one of the other threads so i'm keeping the es100's in mind.
as for the Toyo T1-S, i'll look into them!
thanks for the advice.
Old Apr 19, 2005 | 10:39 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: (Top-Fuel)
for any tire in 14, or 15" wheel.. tires arn't going to be your biggest concern. if your going to turbo a ITR, your gunna have to think about some serious traction.. if i were you, ide get some decent street tires, and enjoy them, untill you REALLY need traction. i have ES100's on all my cars, and i love them.
Old Apr 19, 2005 | 10:46 PM
nocturnaldragon's Avatar
When I bought my good year they were great, untill they wore a bit then they turned into pure crap.
I had a set of firestone firehawks that were inexpensive, wore great, and held up traction wise till the end.
Now im curently running a set of good yr again, i forget what kind, and there so so, but the price was right. (Free)
Im going to goto michelin in a few weeks, once again the price was right. (Free)
If i had to buy a set again tho id go with the firestone, otherwise the soyo's make a good tire, along with sumoto i belive....
But thats my 2cents and shouldent be taken as fact...
Old Apr 19, 2005 | 11:33 PM
JAMinCiViC's Avatar
yoko 100's
Old Apr 19, 2005 | 11:37 PM
Blk00EJ8's Avatar
Default Re: (JAMinCiViC)
I have to put in a good word for Yoko Parada Spec IIs. Kind of soft with 300 wear rating, but they stick really well on the corners.
Old Apr 19, 2005 | 11:43 PM
EeeJayEight's Avatar
Default Re: (EKcivicEX)
get azenis... they are JDM
just playing.. i have some michelin pilots that came with the wheels i got.. they grip very very well... i love them
Old Apr 20, 2005 | 12:08 AM
will@strd's Avatar
Toyo came out w/ T1-R to replace T1S
I had the T1S before and it was good
Old Apr 20, 2005 | 12:39 AM
goofyej6's Avatar
Default Re: (will@strd)
Hankook RS Z212
Old Apr 20, 2005 | 12:43 AM
Outrun's Avatar
What's more important, grip or treadlife? Remember that they are mutually exclusive.
If you want something that's decent all around, try Potenza RE750 or Toyo Proxes 4.
If you want something with great grip in the wet or dry, try Potenza S-03, Goodyear F1 GS-D3, Toyo T1-S. S-03 probably has more ultimate dry grip of the three, and about the same as the others in the wet. They are all better than the ES100.
Old Apr 20, 2005 | 06:49 AM
Top-Fuel's Avatar
Default Re: Advice: What tires are worth purchasing... (Outrun)
w0w thanks alot guys.
I e-mailed "Discount Tire Direct" and they said:
The smallest rim diameter for the Pirelli PZero Nero M+S tires
is 16''. If your car is lowered more than 1.5 inches, the tire
size needed will be a 195/50-15. Otherwise, you can use a 195/55-
15 or a 205/50-15 for the 15x7 wheels. A tire that you may want
to consider is the Kumho ASX for a longer lasting performance
all season tire like the Pirelli.
Hmmm guess I'll have to search up the Toyo T1-S.
Old Apr 20, 2005 | 07:23 AM
NA95d16z6's Avatar
BF Goodrich Traction T/A i got for $56, retail for about $75
excellent traction, nice ride, and good life.
BF Goodrich G-Force (non Drag-Radials) Best tires in the world.
Old Apr 20, 2005 | 09:20 AM
nsxtasy's Avatar
H-T Order of Merit
What are your priorities? Dry traction, wet traction, snow traction, treadlife, cost, etc?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Top-Fuel &raquo;</TD></TR><TR><TD CLASS="quote">the Pirelli PZero Nero M+S tires</TD></TR></TABLE>
Are you looking for all-season tires because you plan to use them on snow and in frigid cold? If not, there are better choices than the M+S all-season tire...
Old Apr 20, 2005 | 09:32 AM
thundergrey94ls's Avatar
Default Re: Advice: What tires are worth purchasing... (thundergrey94ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">man i just bought some falken ziex's for $38.</TD></TR></TABLE>
where did you get them for $38?
