INSTALLING TRACTION BARS!! HELP!!
Old Apr 13, 2005 | 03:58 PM
SpOoNisMyFriEnD's Avatar
Default INSTALLING TRACTION BARS!! HELP!!
guys i ordered a set of lakewood traction bars for my ek hatch...this is the correct set because all the part numbers all match up to my bars and for my car...in the instructions is says for me to remove the bolt that is on the front side of my lower control arm, the one other than the one attached to the strut fork...well i do not have that bolt that they tell me to remove....now what? do i drill a new hole? i have no clue and it is very frustrating.
http://go.mrgasket.com/pdf/50100,50101.pdf
this is a link for the instructions on installing them....look at figure 1. this will show u what i am talking about....
ANY IDEAS!!!! thanks for the help
Old Apr 13, 2005 | 04:11 PM
2lua's Avatar
Default Re: INSTALLING TRACTION BARS!! HELP!! (pebblepusher101)
no you don't have to drill anything just remove the bolt and rebolt it back with the supplied L bracket.
Old Apr 13, 2005 | 04:13 PM
yes i know it says to remove the bolt, but it says to remove the bolt that is not attacthed to the strut fork, besides the bolt on the strut fork....i do not have one? i have no clue?!
Old Apr 13, 2005 | 04:25 PM
evosol's Avatar
Default Re: (pebblepusher101)
you should have one. you see how your lower control arm is 2 peice. you will want to use the bolt used to hold the other half of your LCA together. Its the closest one to the shock fork.
2lua's Avatar
yes, you have to back up about 2inch and you see another bolt that attached to lca. cause the lca is made up of 2 pcs.
Old Apr 13, 2005 | 04:45 PM
Default Re: (2lua)
this is a pic of my lca...which bolt????
Old Apr 13, 2005 | 04:52 PM
ne one
2lua's Avatar
there should be a bolt about 2 inches, but looked at your pic there isn't one there! what year is your car?
Old Apr 13, 2005 | 04:53 PM
its a 97 ek hatch with 99 si lower control arms....
Old Apr 13, 2005 | 04:57 PM
2lua's Avatar
well you have to send them back and ask for the set for 99 si. or you can switch to an 98 ex.
jdmGSR.fo0!'s Avatar
it might be the wrong kit for the car then... that is some weird sheit mang
Old Apr 13, 2005 | 04:59 PM
well i ordered them from eric at titan....he has these forsale in the classifieds, and the are supposed to fit ALL civics 92-00
https://honda-tech.com/zerothread?id=1123181
thats the link
someone asked if they fit si lca's and he said yes...see for yourselfs!!
Modified by pebblepusher101 at 6:14 PM 4/13/2005
Old Apr 13, 2005 | 05:04 PM
2lua's Avatar
yes it will fit your car with stock lca not the 99 si though. well that is false claim. can you ask for a difference set or money back? or you can find an ex lca. why did you swap out for si lca anyway? cause you want front sway bar or something?
Old Apr 13, 2005 | 05:15 PM
well i thought they would fit...he did say 92-00 so i guess i will have to talk to him and find out...
91 b20 integra
11
May 18, 2013 03:33 PM
maxspeed96ct
Jul 11, 2008 04:09 PM
komat
20
Dec 26, 2004 10:04 PM
TheHatchHog
10
Jul 29, 2004 07:15 AM
unknown317
Jul 27, 2003 09:23 PM
