wiring for A/C and radiator fan 91 EF hatchback
Old Apr 13, 2005 | 02:40 PM
OldSkoolEF's Avatar
Default wiring for A/C and radiator fan 91 EF hatchback
This is my first post ever. Up until now I have always been able to search and find the info I needed. I didn't even register until recently because I never needed to.
Now the question. I have a 91 EF hatchback with a B16 swap. It has a full size radiator and A/C with both fans installed. I have a clearance problem with the A/C fan and the header touching. I would like to remove the A/C fan and rewire the other fan to do double duty as the A/C and the radiator cooling fan. I don't want to use a manual switch or anything like that. I want it to be all automatic. I know it can be done. I just can't figure out how.
Old Apr 13, 2005 | 03:08 PM
dr_latino999's Avatar
Default Re: wiring for A/C and radiator fan 91 EF hatchback (OldSkoolEF)
Ever think of installing slim line fans?
Old Apr 13, 2005 | 04:17 PM
Super Chicken's Avatar
Both fans are required for the A/C to work correctly. So rewiring the other fan to do "double duty" won't actually change anything. The one fan (on the passenger side ) should already come on when the A/C comes on. You r condensor needs alot of air moving across it to cool correctly, when you're at speed it doesn't need the fans, but when you're stuck in traffic idling is when you need it most!
Osbjoey
Jul 3, 2012 05:20 PM
GRANT!
Oct 27, 2009 03:37 PM
HiChanDC2R
Oct 15, 2009 01:31 PM
Charlie Moua
Aug 27, 2007 03:39 PM
