headlight dim...ground???
Old Apr 13, 2005 | 02:18 PM
sik_sol's Avatar
B A N N E D
Default headlight dim...ground???
hey the battery was hooked up backwards in my car, and now the drivers side headlight and corner lights are dim...the bulbs are brand new...ive checked the fuses, and they were all ok, so where do i check for a ground?
i mean i followed the wires from the bulbs themselves, and they trace back into the cabin in the dash i guess....any idea where the ground is?
i heard something about a grounding pack, does anyone know where that is?
thanks
Old Apr 13, 2005 | 03:05 PM
theinfamouskonrad's Avatar
Default Re: headlight dim...ground??? (sik_sol)
i believe this is it...
someone correct me if i'm wrong
Old Apr 13, 2005 | 04:55 PM
sik_sol's Avatar
B A N N E D
that was it dude...the spade that it was on was corroded over...ground it down with sand paper, lit right up....thanks main
Modified by sik_sol at 6:43 PM 4/13/2005
Old Apr 13, 2005 | 05:50 PM
PrettyLude's Avatar
that's a relay
Old Apr 14, 2005 | 01:51 PM
alpine_hikr's Avatar
Yeah that is definately a headlight relay, and corrosion would definately cause a high resistance problem with your headlights which would cause them to go dim. Good find.
OregonDucks
Honda Civic (2001 - 2005)
Dec 24, 2017 10:42 AM
hotaccord243
May 29, 2008 01:00 PM
Frost7177
Jan 8, 2008 01:00 AM
EK VTi
Acura TL, RL & ZDX
Mar 6, 2006 08:22 AM
WANARUNM
Nov 30, 2004 06:39 PM
