Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
OMNI POWER COILOVERS!! GREAT DEAL FROM NEW SITE SPONSOR!! IN STOCK NOW!!
Old Apr 13, 2005 | 01:12 PM
ImportAutoPerformance.com's Avatar
Default GREAT DEAL FROM OMNI DIRECT DISTRIBUTOR!! OMNI POWER COILOVERS!! IN STOCK NOW!!
UPDATE!! EG LCA'S ARE ON THE WAY!!! PREORDER YOURS NOW BEFORE THEY ARE BACKORDERED AGAIN!!! THEY ARE A NEW, MORE APPEALING DESIGN AND LIGHTER WEIGHT!!! CALL TOLL FREE 1-888-672-0066 OR PURCHASE 24/7 ONLINE AT http://WWW.IAPDIRECT.COM
<U>WE ARE ONE OF ONLY A FEW OMNI WD DIRECT DEALERS!! IF YOU BUY OUTSIDE OF THESE, YOU ARE BUYING FROM THE MIDDLE MAN!!</U>
Hello, our company is fairly new to the HT forum. To start off we would like to offer members the Omni-Power Coilover systems for $650 shipped (some applications are more)! They are available for the following vehicles:
<U>Omni Power Full Coilovers $650 with free shipping</U>
88-91 Civic/CRX
92-95 civic (street and sport in stock!)
96-00 civic (street and sport in stock!)
01+ civic (ep3 and EM2 coming very soon) $779
94-01 Integra (street and sport in stock!)
90-93 Integra (currently on backorder with OMNI)
02+ RSX (In stock within 30-60 days) $779
90+ Accord (90-97 and 98-02 In stock!)
WRX (backorder) $779
EVO8 (sport in stock!, then on backorder) $779
and more!
<U>Omni Power Drag Rear Coilovers $409 plus s/h </U>
96-00 civic
92-95 civic
94-01 Integra
94-01 Integra Type-R
Please read below for detailed info on this coilover system. They have received much praise from Civic owners, EVO8, WRX and more. You will not see another comparable coilover system anywhere near this price range.
Coilover info from Omni-Power:
When manufacturing a sophisticated suspension system there are many aspects that need to be considered to achieve extraordinary results. After exhausting efforts we feel that we have produced the ultimate coilover system.
We not only wanted a system that performed well on the track but also could be driven on the street. This is not as easy as it may seem, however we feel that we have achieved the perfect combination! Using many of the technologies found in Porsche 911 GT2/GT3 coilovers, we carefully configured bump and rebound settings for each specific application to produce optimum driving dynamics. We used spring Sport (F=12k, R=10k) and Street (F=10k, R=8K) and damper rates that yield exceptional handling characteristics coupled with unsurpassed street drivability.
Our coilovers can be raised or lowered, up to 4”, from two separate positions which allows the user to raise or lower their vehicle without affecting spring preload or damper stroke length. We incorporated large 46mm pistons along with 20mm shafts which we found far superior to typical smaller piston/shaft coilovers. By using large 46mm pistons we were able to greatly reduce the stroke length, while still moving the same amount of fluid, resulting in unprecedented efficiency. All coilover systems include high grade aluminum pillow mounts further enhancing overall control. We used CNC Wound SAE 9254 Racing Springs which were found to be the longest lasting spring on the market that showed no tendencies to sag.
So whether you are looking for a great track set up or you need a suspension that adapts to public roads, you have found the right coilover. Omni-Power, Designed and manufactured for customers who demand the very best!
Summary:
46 mm Piston Size, Resulting In Superb Overall Control.
20 mm Shaft Designed To Withstand Both Track Abuse As Well As Road Imperfections.
CNC Wound SAE 9254 Super High Quality Springs.
Extensive Research And Development Went In To Choosing Precisely Matched Spring & Damper Rates Specific To Each Application. The Result Is Outstanding Ride Quality & Incredible Handling Characteristics!
Pics below for reference only and are not the images of the exact coilover for each vehicle.
OMNI Lower Control Arm $114 with free shipping!!
These aluminum arms weight approx. 2.5 lbs less than stock and have a much nicer appearance! Once installed, these can be seen from the rear of the vehicle. Included are:
Two (2) silver rear lower control arms
Rubber bushings already pressed in
Sway bar mounting holes
Applications:
96-00 Civic (EK) In stock!
92-95 Civic (EG) ON THE WAY NOW!!
94-01 Integra (DC) ON THE WAY NOW!!
Call us toll free at 1-888-672-0066 to purchase your set or to ask questions.
We are here to help
Modified by peteriap at 9:02 AM 4/26/2005
Modified by peteriap at 3:45 PM 4/27/2005
Modified by peteriap at 7:25 AM 5/2/2005
Modified by peteriap at 10:32 AM 7/28/2005
Modified by peteriap at 10:51 AM 7/28/2005
Old Apr 13, 2005 | 01:20 PM
Default Re: OMNI POWER COILOVERS, CAMBER KITS, LCA'S, ETC!! GREAT DEAL FROM NEW SITE SPONSOR!! IN STOCK NOW!
More:
<U>Slipover Coilovers $169 Shipped! </U>
These Are The Same Coilover Used By Race Winning World Challenge Driver Roger Foo.
These coilovers are designed to work with your stock shocks or with aftermarket shocks.
Spring rates are 448 lb's in the front & 336 lb's in the rear, aimed towards the performance minded enthusiast without sacrificing comfort!
The coilover kit comes with lowering wrenches.
Applications:
88-00 Honda Civic (1 set left then... long Backorder)
90-01 Acura Integra (1 set left then... long Backorder)
<U>Omni-Power Camber Control Arms with free rear shims $150 Shipped! </U>
Omni-Power adjustable front camber kits are designed to replace the whole factory A Arm allowing up to +- 4 degrees of camber adjustment. They come equipped with high quality ball joints and nuts able to withstand track abuse as well as the rigors of everyday street driving. These are the same kits supplied to Race Winning World Challenge Driver Roger Foo!
These Are The Same Camber Kits Used By Race Winning World Challenge Driver Roger Foo.
Will fit all 92-95 Honda Civics & all 94-01 Acura Integras, including the Type R. These camber kits are designed to replace the whole OEM upper A arm on each side.
This camber kit allows + or - 4 degrees of adjustablity in the front and a shim kit is provided for adjusting camber in the rear.
They fronts also come equipped with high quality ball joints and nuts.
Rear Shim Kit Included
Applications:
96-00 Civic (EK) Black Available
92-95 Civic (EG) Red Available
94-01 Integra (DC) Red Available
Old Apr 14, 2005 | 05:45 AM
PM's replied. Thanks.
Old Apr 14, 2005 | 01:49 PM
PM's Replied.
Old Apr 15, 2005 | 02:22 PM
Thanks for the orders guys!
Old Apr 18, 2005 | 01:03 PM
realis9's Avatar
Default Re: GREAT DEAL FROM NEW DIRECT DISTRIBUTOR!! OMNI POWER COILOVERS!! IN STOCK NOW!! (peteriap)
I highly recommend this guy peter awesome costomer service answered all my question. Would do business again.
Old Apr 18, 2005 | 01:38 PM
Default Re: GREAT DEAL FROM NEW DIRECT DISTRIBUTOR!! OMNI POWER COILOVERS!! IN STOCK NOW!! (realis9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by realis9 &raquo;</TD></TR><TR><TD CLASS="quote">I highly recommend this guy peter awesome costomer service answered all my question. Would do business again.</TD></TR></TABLE>
Great! Thank you for your business! Keep them coming guys!!
Old Apr 19, 2005 | 02:02 PM
Thanks for the questions guys! Keep 'em coming!
Old Apr 20, 2005 | 01:55 PM
Bump
Old Apr 21, 2005 | 01:15 PM
Default Re: (peteriap)
Keep the questions coming!
Old Apr 21, 2005 | 02:49 PM
stageup's Avatar
nothing for ef's? i got a 91 crx mang
Old Apr 25, 2005 | 01:56 PM
Default Re: (stageup)
Yeap, we can get you the EF coilovers as well. $650 with free shipping. PM/email me if you have any questions. Item in stock and ready to ship.
Old Apr 26, 2005 | 06:41 AM
Cliffjumper2's Avatar
I'm interested in the omnipower lca's but have heard that they fitment issues with the swaybar, is this true?
I'd like to order a set. I have a 97 integra RS.
Old Apr 26, 2005 | 07:51 AM
Default Re: (Cliffjumper2)
The only vehicle I have heard of fitment issues on is the Type-R. Unfortunately, the EG/DC LCA is on backorder for approximately 4 weeks. If you like, you can preorder them with us so we can reserve a set for you on the next order.
Old Apr 26, 2005 | 08:57 AM
thanks for the info
too bad it's back ordered
Old Apr 26, 2005 | 11:20 AM
GReddyTurboCoupe's Avatar
Got a price on the DRAG Coil overs, those are what i want.
Old Apr 27, 2005 | 02:41 PM
Default Re: (brianmvalentine)
Are you looking for just the drag rears? Just added to the listing.
Old Apr 27, 2005 | 03:03 PM
13DevilsCamry's Avatar
Is it possible for you to get custom spring rates? Or are those the only two spring rates that you offer?
Old Apr 28, 2005 | 06:34 AM
Default Re: (13DevilsCamry)
Let me know what your are looking for and I will see what I can do.
Old Apr 29, 2005 | 12:43 AM
bobobob's Avatar
how long before back in stock?
Old Apr 29, 2005 | 10:11 AM
Default Re: (bobobob)
Let me know which item you are looking for and I will find an eta for you.
Old May 2, 2005 | 06:26 AM
Have a good week guys/girls!
Old May 5, 2005 | 12:07 PM
Old May 6, 2005 | 04:36 AM
02civic_rida's Avatar
Peter's a great guy! deal with him on 7thgen , i have yet to buy anything from him yet, im hoping on these coilies, he's always got the answers to my questions, and if he doesnt, he goes and does the research for them and comes back with the correct info.... Bump for a great Guy and a great product! AND TELL ME WHEN THEY ARE READY FOR OUR DAYAM 7thens!!!!
Old May 6, 2005 | 06:36 AM
Default Re: (02civic_rida)
Thanks for the post! I will definitely let you know as soon as they are available (hopefully soon).
