All of the sudden it sounds like im running on 3 cylinders?
Old Apr 13, 2005 | 12:38 PM
kholmes's Avatar
Default All of the sudden it sounds like im running on 3 cylinders?
Ive got an h22a in my 98 hb and today I was driving, I got on it high in the rpms like 7-7.5k and then the car started running kinda rough, when I got on the gas again normally it sounded like theres only 3 cylinders working. Like a v8 or something.
I checked compression, wires, plugs, distributer, ext. coil. Everything looks good. Timing belt still at TDC. Any other things to check?
Old Apr 13, 2005 | 02:15 PM
kholmes's Avatar
Default Re: All of the sudden it sounds like im running on 3 cylinders? (kholmes)
Come on, i need input on this. I checked vacuum lines and my fuel pessure gauge shows a steady flow. Any ideas?
Old Apr 13, 2005 | 07:41 PM
The Phil's Avatar
Um, h22a redline is 7200rpm. You weren't hitting the rev limiter?
Old Apr 13, 2005 | 09:52 PM
kholmes's Avatar
Default Re: All of the sudden it sounds like im running on 3 cylinders? (xthephilx)
no, its set at 8k for the limiter but always take it to 7500. Anyways it turne out to be the resister box.
Old Apr 14, 2005 | 04:47 AM
iakona's Avatar
how did you figure out it was the box? i've gone through a set of injectors already and fear i may need to do it again.
Old Apr 14, 2005 | 09:08 AM
kholmes's Avatar
Default Re: (iakona)
The box had white powder coming out of it so I opened it and found a wire disconnected.
Funny thing is I pulled the head too. Oh well, Im gonna drop the head off anyways to see if theres any issues with that and I wanted to see if I had Type S pistons for sure since the guy I bought the motor from said I did.
donaldb128
Jul 1, 2014 06:52 PM
RudeLude
May 3, 2005 10:32 AM
kholmes
Apr 14, 2005 07:01 AM
Acme2eg6
41
Jun 29, 2003 02:17 AM
