Help me calculate my compression ratio
Old Apr 13, 2005 | 12:28 PM
itralex's Avatar
Default Help me calculate my compression ratio
I need help calculating my compression ratio on my setup and lining up the cam gears.
The pistons i have are rated at 12.5:1 cr and the head that i have is milled 0.040. from what i know. This setup puts me at 13.1:1 with advancing the cam gear something like 4 degrees with the stock head gasket.
Now, I have a 0.051 cometic headgasket to lower the compression. With the cometic Headgasket my compression will be 12.6:1 correct? what i"m wondering is if this is correct and what would i do with the cam gears in this situation
and here is some eye candy g00tness for looking at this thread :D
these are the pistons taht i'm using
Old Apr 13, 2005 | 10:12 PM
itralex's Avatar
Default Re: Help me calculate my compression ratio (itralex)
bizzzump for some help
Old Apr 14, 2005 | 10:16 AM
PAndADc2's Avatar
i believe this might help you http://www.c-speedracing.com
skippy33
Feb 7, 2021 05:34 PM
komat
14
Sep 8, 2009 05:16 PM
lv2exl8
Jun 24, 2006 09:57 AM
Chief Wenceslaw
Feb 7, 2006 05:59 PM
red91g2
Mar 3, 2003 12:12 PM
