alignment/steering issues.
Old Apr 13, 2005 | 12:28 PM
rodvang's Avatar
Default alignment/steering issues.
I went in to get my alignment done the other day and they said I needed new inner tie rods and outter tie rods...I checked them when i got home and was wondering how do you know if they are bad? Also..the rack end on the passenger side is loose..im guessing that is bad? does that need to be replaced also..or does it just need to be tightened?
Old Apr 13, 2005 | 01:58 PM
rodvang's Avatar
Default Re: alignment/steering issues. (rodvang)
bump cause im a noob.
Old Apr 13, 2005 | 02:05 PM
MiX's Avatar
MiX
bump i would like to know too.
Old Apr 13, 2005 | 02:06 PM
litterbox's Avatar
I am a (Trial User) Army
To check if your outer tie rods are bad jack up your car. Grab your tire and wiggle it back and forth from left to right. If is there is alot if wiggle (play) your tie rods are bad. The ball joints are most likely worn. I don't know about your other questions.
Old Apr 13, 2005 | 04:19 PM
rodvang's Avatar
bump
Old Apr 13, 2005 | 11:13 PM
rodvang's Avatar
bump for sleep.
Old Apr 19, 2005 | 12:27 PM
MiX's Avatar
MiX
bump
portablenarc
Suspension & Brakes
Oct 10, 2018 10:29 AM
Android Jr
Suspension & Brakes
Sep 21, 2016 03:44 PM
alldemtingz
Oct 24, 2008 12:36 PM
Dylanamus
Mar 2, 2008 07:06 PM
greyzone
Suspension & Brakes
14
Aug 10, 2005 10:15 AM
