What kind of assembley lube do you guys use?
can you buy arp assembly lube seperate from a set of arp fasteners? I know that my arp headstuds came with some, but where can I get more if I run out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">lubrimatic...assembly white grease</TD></TR></TABLE>I don't know if that brand is any different then the rest but white grease is usually the last thing you'd want to assemble with.The grease clogs the oil filter very easily.I use Lucas oil treatment mixed 1/2 w/50 weight oil if it's going to run soon,and straight Lucas if it's going to sit for awhile.It works very well is cheap and stays on the surface you put it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Black Graphite...works awesome and is cheap!</TD></TR></TABLE>
I think this is what I used. It's the stuff they have at napa.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DRAGLS »</TD></TR><TR><TD CLASS="quote">lucas oil stabilizer</TD></TR></TABLE>
Same here
Same here
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">moly is what i use</TD></TR></TABLE>Moly is just as bad as white grease in clogging oil filters.Use it only on bolt treads.
sorry to thread jack but this is kinda similar... if my USED sc61 turbo is to sit there for a while.. do i need to put any lube/motor oil in it to prevent the seals from going bad?
