94 b18c obd1 into a 98 civic ex obd2
Old Apr 13, 2005 | 12:03 PM
b18c inside's Avatar
Default 94 b18c obd1 into a 98 civic ex obd2
What all will i need to make this swap work? Please help me out i'm new to this. I have the ECU jumper. what engine harness will i need along with mounts, axles, shift linkage? Please just let me know what i need completely. If i need engine mounts, where can i buy them at for a resonable price? Thanks
Old Apr 13, 2005 | 03:08 PM
VTECVillain's Avatar
Default Re: 94 b18c obd1 into a 98 civic ex obd2 (Phatcivic213)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 &raquo;</TD></TR><TR><TD CLASS="quote">what engine harness will i need</TD></TR></TABLE>
Reuse the stock EX harness and modify it, that's the BEST way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 &raquo;</TD></TR><TR><TD CLASS="quote">along with mounts</TD></TR></TABLE>
You need a driver's side 99-00 Si engine mount bracket and rear bracket, the rest will come from your stock EX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 &raquo;</TD></TR><TR><TD CLASS="quote">axles, shift linkage?</TD></TR></TABLE>
94-01 Integra (any model) or 99-00 Civic Si axles, int. shaft and linkage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatcivic213 &raquo;</TD></TR><TR><TD CLASS="quote">If i need engine mounts, where can i buy them at for a resonable price?</TD></TR></TABLE>
No aftermarket mounts needed other than what I listed above.
Old Apr 14, 2005 | 04:44 AM
Ej6B20's Avatar
Default Re: 94 b18c obd1 into a 98 civic ex obd2 (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
No aftermarket mounts needed other than what I listed above.</TD></TR></TABLE>
When you say "rear" is that the rear tranny mount? and what about the front trAnny mount?
Old Apr 14, 2005 | 05:12 AM
Default Re: 94 b18c obd1 into a 98 civic ex obd2 (Ej6B20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej6B20 &raquo;</TD></TR><TR><TD CLASS="quote">When you say "rear" is that the rear tranny mount? and what about the front trAnny mount?</TD></TR></TABLE>
Yes, the rear tranny bracket. Not the rubber mount that bolts on the rear cross member but the bracket that connects that mount to the tranny. The front lower mount needs to be from a 94-01 Integra or 99-00 Si as well as the A/C bracket if you are only using it as a dampening mount. If you want to retain A/C you'll need a Del Sol VTEC A/C bracket, pretty sure a CRV one will work as well.
eknorcal
Northern California (Sales)
10
Nov 14, 2006 06:12 PM
dohc boy 96
Dec 7, 2005 01:55 PM
b18c inside
Apr 10, 2005 07:04 PM
Awar318
Mar 29, 2004 08:20 PM
BLK99VTECR
May 4, 2003 06:33 AM
