is there a tool to change valve springs/ ret. without removing the head
Old Apr 13, 2005 | 11:35 AM
djmota's Avatar
Default is there a tool to change valve springs/ ret. without removing the head
is there such a magic tool? I am getting a cam, springs, and retainers soon and want to avoid taking off my head again if possible.
Old Apr 13, 2005 | 11:47 AM
PrettyLude's Avatar
leak down tester, use that
Old Apr 13, 2005 | 12:56 PM
Muckman's Avatar
Moderator in Chief
Default Re: is there a tool to change valve springs/ ret. without removing the head (djmota)
air pressure is your friend.
Old Apr 13, 2005 | 12:59 PM
tgreaves's Avatar
There is a tool that bolts to the top of the motor that allows you to remove the springs without removing the head..
You fill the cylinder with air pressure to keep the valve from falling back in..
Old Apr 13, 2005 | 01:37 PM
suckawillis's Avatar
Default Re: is there a tool to change valve springs/ ret. without removing the head (tgreaves)
alright, this is ghetto, but when i did mine, i just set each piston at the top while doing it. i dropped one valve, and it was a bitch to fish it up, but i got it. the second time i just used air to fill the comb. chamber so the valves stayed closed.
Old Apr 13, 2005 | 01:48 PM
tgreaves's Avatar
Default Re: is there a tool to change valve springs/ ret. without removing the head (suckawillis)
Or you can use rope in the cylinders to keep the valves from dropping..
Old Apr 13, 2005 | 02:08 PM
djmota's Avatar
nice that'l save me some time.
MindLess311
14
Feb 25, 2008 07:29 PM
boosted k20
Aug 20, 2004 12:12 PM
Evs-One
11
Oct 25, 2002 05:27 PM
arw321
Sep 30, 2002 05:28 PM
