Spoon VS. Toda???
Old Jan 29, 2002 | 03:54 PM
b18csol's Avatar
Default Spoon VS. Toda???
i have a del sol, and just ordered my b18c1 jdm motor, i am trying to figure out if i should get the Spoon cams or the TODA B's, everyone please give their opinions.
Old Jan 29, 2002 | 03:59 PM
94gsr4d's Avatar
Default Re: Spoon VS. Toda??? (b18csol)
What do you plan to do with your car....drag, road race, or what?
i haven't heard much about spoon but toda B's are for midrange power/road racing
imo you should get Jun 3 if your gonna drag but you need 12:1 compression + tuning to bring them out...
Old Jan 29, 2002 | 04:05 PM
Project SSAP1's Avatar
Default Re: Spoon VS. Toda??? (94gsr4d)
imo toda cams have a rough idle...jun cams r less aggressive but yet kick ***...go for the jun 2 if u wanna road race or jun 3 if u wanna drag..only bad thing is that they make only power at the top of the rpm ..like 7k on and in order for them to work really well u need a high comp so they can breath....if u want the toda cams and dont mind the rough idle go for the toda b's
Old Jan 29, 2002 | 04:08 PM
b18csol's Avatar
i plan on road racing, and dragging on weekends, but it is still my daily driver.
Old Jan 29, 2002 | 04:09 PM
b18csol's Avatar
Default Re: Spoon VS. Toda??? (B18cKiller)
what about Spoon? how do they compare with Toda?
Old Jan 29, 2002 | 04:11 PM
B2FiNiTY's Avatar
The spoon cams are a lot more mild than the Toda B's.
Search is your friend, please use it: https://honda-tech.com/zerothread?id=109400 https://honda-tech.com/zerothread?id=109595
Old Jan 29, 2002 | 04:15 PM
spoon cams are not that aggressive..those cams r made just for a car that is porperly tuned using spoon parts..imo a waste of money to buy them.if not tuned correctly they r just liek buying a set of ctr/itr cams...just stick with either toda or jun...or ctr/itr if u wanna just chill and not rev past 8500 rpm...ctr/itr cams kick *** in the mid-range especially if u r on a budget...depends on what u wanna do..either ctr/itr cams more street cams for midrange power only and no drag racing to and can go past 8500 rpm or toda/jun cams for drag and kick *** power at the top end...what do u wanna do??
Old Jan 29, 2002 | 08:33 PM
alexboy's Avatar
I feel your comparing to different purpose cams.
Quality they are both top notch however the spoons may have the slight egde because the are made by honda
Performance well i know the todas will give better results especailly in the top end IF AND ONLY IF you are willing to purchase an aftermarket vavle train, possibly upgrade your bottom end and get tuned the spoons are more of a drop in set off cams ( alittle more aggressive than itr stock cams
Old Jan 29, 2002 | 09:32 PM
1 2 NV's Avatar
JUN less aggressive??? they have 10 degrees more duration than TODA Cs. its true they idle like poo poo though. i have JUN 3s, extremely aggressive, stock idle, better gas mileage than stock too. i dont know how that came about but the odometer dont lie.
an2ny888
May 3, 2005 08:27 PM
Engn
Honda S2000
13
Sep 24, 2003 02:13 PM
Hard2Find
Aug 8, 2002 02:23 PM
Tyson Ballou
Dec 27, 2001 09:56 AM
AllMotorITR
Oct 7, 2001 07:22 PM
