vtec pressure switch Q"
Old Apr 13, 2005 | 08:30 AM
EK FLY's Avatar
Default vtec pressure switch Q"
hi my question is wich cable of the vtec pressure switch is the one that goes to groun and wich to the ecu ?I have preblem with the engine and I really need to have vtec runing on my car
btw I have a jdm p72 ecu
Old Apr 13, 2005 | 10:33 AM
Katman's Avatar
Default Re: vtec pressure switch Q" (racing_beat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat &raquo;</TD></TR><TR><TD CLASS="quote">hi my question is wich cable of the vtec pressure switch is the one that goes to groun and wich to the ecu ?I have preblem with the engine and I really need to have vtec runing on my car
btw I have a jdm p72 ecu </TD></TR></TABLE>
D6 is the pin location for the VTPS wire which runs out through your firewall to a main harness plug on your passenger side shock tower. Leading off the this plug is where the VTPS splits out into the 2 wires that you see on the VTPS plug. 1 is black (ground) & 1 is a colored wire (power) usually orange/blue color.
[EDIT]
Is your JDM P72 ecu OBD1 or OBD2?
Modified by Katman at 1:17 PM 4/13/2005
Old Apr 14, 2005 | 03:57 AM
EK FLY's Avatar
Default Re: vtec pressure switch Q" (Katman)
obd1
Old Apr 14, 2005 | 06:14 AM
EK FLY's Avatar
now one more question
when i bough the engine harmness I got it without the vtec pressure switch connector , and I was woundering if i can use one frome the stock d15b8 engine I mean I cut one for example the iab or any other connector that fits the vtec pressure switch and then put the wires together and ? is there any way I could do that
Old Apr 14, 2005 | 07:30 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racing_beat &raquo;</TD></TR><TR><TD CLASS="quote">now one more question
when i bough the engine harmness I got it without the vtec pressure switch connector , and I was woundering if i can use one frome the stock d15b8 engine I mean I cut one for example the iab or any other connector that fits the vtec pressure switch and then put the wires together and ? is there any way I could do that </TD></TR></TABLE>
yes you can totally do this
Old Apr 14, 2005 | 08:35 AM
EK FLY's Avatar
THANKS ! BRO..........
89sparks
Sep 4, 2007 06:35 PM
blinger
Apr 27, 2007 02:27 PM
nutball72
Aug 26, 2006 10:54 AM
Ak_ef9
17
Feb 16, 2006 03:34 AM
EK FLY
Apr 14, 2005 08:40 AM
