I Need Your Help
Old Apr 13, 2005 | 05:12 AM
dip-set's Avatar
Default I Need Your Help
the car is a 94 civic hatch,all stock, and auto...
i flushed the coolant last weekend,cause it was filthy,old etc...
replaced with fresh coolant, bled it etc, now the cars temperature flucuates between almost overheating and normal temp while driving...it will go up slowly, then come back down ,then up and down, sometimes slow, sometimes faster...
also the car seems to stumble a lil now at idle and once in a while ,while driving, im thinking there still air in the system,or the thermostat is on its way out, can anyone help me put here, the car was fine before i flushed the coolant...
thanks..
Old Apr 13, 2005 | 07:54 AM
dip-set's Avatar
Default Re: I Need Your Help (dip-set)
page 1 bump
ideas?
Old Apr 13, 2005 | 07:55 AM
Prod's Avatar
how well did you bleed it ? i think thats the first and easiest thing to try and do
Old Apr 13, 2005 | 08:10 AM
Rhythm Racer's Avatar
Default Re: I Need Your Help (Prod)
i had a problem a little like this,my temp kept getting hotter and hotter and then it would drop and then do it again,and i kept having to keep adding coolant. it turned out to be that i had a blown head gasket
Old Apr 13, 2005 | 08:17 AM
Luserkid's Avatar
Default Re: I Need Your Help (Rhythm Racer)
^ Ouch. I dont think this guy has that problem.
Try bleeding your system again and that should fix it.
Old Apr 13, 2005 | 09:58 AM
dip-set's Avatar
Default Re: I Need Your Help (Luserkid)
thanks man, any tips on bleeding it, maybe im not doing it right...thanks..
btw im not leaking any coolant
Old Apr 13, 2005 | 10:08 AM
EgRedSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">^ Ouch. I dont think this guy has that problem.
Try bleeding your system again and that should fix it. </TD></TR></TABLE>
Old Apr 13, 2005 | 11:13 AM
penguinman717's Avatar
Default Re: I Need Your Help (EgRedSi)
yeah i agree try to bleed it again.... it might work..
Old Apr 13, 2005 | 11:54 AM
RedDC5's Avatar
Default Re: I Need Your Help (Civic002KM)
Hmmm, it does sound like a blown head gasket, thats what mine used to do. Could it be a thermostat problem?
Old Apr 14, 2005 | 04:51 AM
dip-set's Avatar
Default Re: I Need Your Help (4door_ridin)
ok i bled it again yesterda and it had a ton of air in the ststem, hopefully all is well now..
i dont see how i could have blown a headgasket, by flushing the coolant..
Hoopdie91
Apr 3, 2016 06:15 AM
KeEpxiTxLiTt
Nov 17, 2007 11:32 AM
SOHC_MShue
Apr 16, 2005 02:42 PM
mightyone
Jun 28, 2003 01:26 PM
flex97itr
Jul 4, 2002 11:04 AM
