zc sohc block with pm7 pistons and a y8 head, ????????
Old Apr 12, 2005 | 11:19 PM
civtegra_hybrid's Avatar
Default zc sohc block with pm7 pistons and a y8 head, ????????
hey I need to know quick I putting this set up, on a zc block (sohc) with pm7 pistons (89 integra), on a y8 head. dose any one know if it will clear???? do I have to advan or retard the timing at all???? is any one running this set up.? pls help building block tommorrow, (spun a rod bearing on old block) pls bump if you check it out, thanks
Old Apr 12, 2005 | 11:22 PM
Default Re: zc sohc block with pm7 pistons and a y8 head, ???????? (civtegra_hybrid)
bump
Old Apr 13, 2005 | 06:17 AM
bump anyoone?????????????????
Old Apr 13, 2005 | 06:44 AM
JIDUM_Undercover's Avatar
haha wow that was the exact same setup i was running in my ef a while back before i realised how much i love bseries. But regarless slap it together torque everything right and roll out, its a pretty quick motor i beat gsr's and si's.
Old Apr 13, 2005 | 06:49 AM
egizzle8
Guest
Posts: n/a
Default Re: (JIDUM_Undercover)
knology.net is your friend
Old Apr 13, 2005 | 07:49 PM
thanks bro there was not prob with the clearance ?
Old May 26, 2005 | 11:28 AM
builthatch's Avatar
MiG-21 superfan
Default Re: (civtegra_hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civtegra_hybrid &raquo;</TD></TR><TR><TD CLASS="quote">thanks bro there was not prob with the clearance ?</TD></TR></TABLE> this is old but just to clarify---
no. there is no issue with clearance- you can even run a hefty cam with p29 piston/ y8 head and have no issues (as long as the head has not been milled extensively (more than .010) and the block hasn't been decked more than .010
vtechsauce
Nov 8, 2010 12:34 PM
xymantec
Jun 13, 2010 01:22 PM
Dante Civic
Feb 11, 2008 10:42 AM
CivicRaping
Mar 19, 2005 04:57 PM
the jdmchop
Feb 3, 2004 10:12 AM
