question on itr ecu into an si
Old Jan 29, 2002 | 02:40 PM
Gump's Avatar
Default question on itr ecu into an si
just got an itr ecu with the imobilizer taken out, but now the car won't turn over. anybody know why it won't? and if anyboudy is wondering no its not stolen, and i did a search.
Old Jan 29, 2002 | 02:42 PM
Solo2Vtec's Avatar
Default Re: question on itr ecu into an si (xlr8 si)
I think its wired a little different
Old Jan 29, 2002 | 02:44 PM
Gump's Avatar
Default Re: question on itr ecu into an si (LSVtec2000)
what do you mean its wired differently?
Old Jan 29, 2002 | 02:51 PM
norice's Avatar
If it is a 2000+ ITR ECU (and I guess it would have to be because the earlier one will not fit a 1999/2000 Si without a harness), it should work. (Car will run very rich apparently, though.)
Are you sure the immobilizer was disabled properly?
Old Jan 29, 2002 | 02:57 PM
Gump's Avatar
Default Re: question on itr ecu into an si (norice)
yeah i'm pretty sure its out, had someone take out thats has a good amount of knowledge with doing this, but it won't turn over the check engine light is on but it really dim and lights up slowly when i try to start the car
Old Jan 29, 2002 | 03:04 PM
norice's Avatar
Try asking on clubsi.com. A lot of people there have done this successfully.
Old Jan 29, 2002 | 03:07 PM
Gump's Avatar
i did a search over there too, and i think they get rid of old threads at the beginning of the year so i can't find anything over there
Old Jan 29, 2002 | 03:30 PM
nfn15037's Avatar
Is your battery dead?
Old Jan 29, 2002 | 03:32 PM
Gump's Avatar
Default Re: question on itr ecu into an si (nfn15037)
nope! its starts fine with the si ecu
Old Jan 29, 2002 | 04:02 PM
SamB's Avatar
New User
What happens if you try and push start it??
Old Jan 29, 2002 | 04:41 PM
Gump's Avatar
Default Re: question on itr ecu into an si (Sam & Bridget)
why would that help?
seems to me that the fuel pump isn't turning on, i can't hear it
Old Jan 29, 2002 | 04:50 PM
JSIR's Avatar
New User
I ran a 98 ITR ECU on my 99 Civic SiR and it ran great, no problems at all with the appropriate harness adapter. With the 2000 I have to assume that they did not remove the immobilizer feature properly, that is why it won't start, either someone did the repair improperly or they bullpoo pooed you that it was removed, it definitely wasn't, no other reason why the ecu wouldn't work.
Joey
Old Jan 29, 2002 | 04:54 PM
Gump's Avatar
Default Re: question on itr ecu into an si (JSIR)
Joey
thats what i was guessing, but you never know maybe the ecu is just bad
Old Jan 29, 2002 | 05:28 PM
kenji's Avatar
25 Year Member
The reason you are not hearing the fuel pump priming when you turn the key to the on position is due to the fact that the '00-'01 ITR ECU has the fuel pump relay wire in a different position than your '99-'00 Civic.
You need to move the wire at A16 to A15 on ECU plug A.
Also, if the immobilizer is not removed from the ITR ECU the car will NOT start unless you have all of the other immobilizer components hooked up correctly.
-kenji
Old Jan 29, 2002 | 05:37 PM
Gump's Avatar
Default Re: question on itr ecu into an si (kenji)
well the guy that took the imobilizer off didn't say anything about that, which is plug a? and how do i find a16, and a15?
Old Jan 29, 2002 | 08:25 PM
Gump's Avatar
ok, just spoke to the guy who took the immobilizer out and he also said compensated for the A16, and A15. so we tried it again, the car still won't turn over, and now another thing we now notice was the radiator fan turns on for no reason, but car has been sitting for about two hours and the motor is cold
Old Jan 29, 2002 | 10:11 PM
SamB's Avatar
New User
Well, from reading your question it sounded like the starter motor wasn't turning the engine over, so if you pupoo poo and it starts well at least that means the ecu is doing something. Was just wildly stabbing in the dark to try and help you, sorry if I misunderstood the problem.
Sam
Old Jan 29, 2002 | 10:16 PM
Gump's Avatar
Sam
thats cool! i appreciate the helpful comments, anyone else? i really want this ecu to work, if not it may become a wiring harness
Old Jan 29, 2002 | 10:20 PM
underrated99si's Avatar
Well I have a ? of my own. When I get my car back from the body shop I am putting a ITR in it and a P73 00-01 ECU and with the imobilizer still in will the car turn on or do I have to
A. get a new ignition with a imobilizer
B. or get imobilizer taken off
C. I have heard that with the imobizer still in and with no mods the hok up is fine and it should work fine
What shoul I do I want the least amount of headaques.
Old Jan 29, 2002 | 10:27 PM
Gump's Avatar
Default Re: question on itr ecu into an si (underrated99si)
thats the ecu i have, just get the immobilizer taken out or get a wiring harness and use another obd2 or ob1 ecu those are the easier ways to do it. and for C. the ecu won't work if the immobilizer is still connected
Old Jan 30, 2002 | 11:24 AM
Gump's Avatar
ok, just went to clubsi posted this same question over there, but they are no help! all they keep on doing is repeating my question for me, and telling me that it has an immobilizer in it that i need to take out, which has already been taken out. people over there like post a answer before reading the damn topic!
[Modified by xlr8 si, 8:26 PM 1/30/2002]
gs-R_swap
Dec 9, 2009 01:36 PM
Tiger_Si
Nov 24, 2008 02:06 PM
Gump
Jan 29, 2002 09:51 PM
Gump
Jan 29, 2002 05:39 PM
