Is there a such thing as a brake angle monitor?
Old Jan 29, 2002 | 02:39 PM
Heat Rave R's Avatar
Default Is there a such thing as a brake angle monitor?
I know there are throttle angle monitors that use the TPS to show how far the throttle is open. Is there an equivalent device to show how much the brakes are down? Maybe the throttle angle monitor could be hooked to something in the brake system to do that?
Old Jan 29, 2002 | 03:25 PM
bob01721's Avatar
Default Re: Is there a such thing as a brake angle monitor? (Heat Rave R)
Not that I'm aware of. Do you mean to show pad wear? Most pads use a little metal "finger" that'll contact the rotor when the pads wear down. When you hear that squeal, you know it's time for new pads.
Or do you mean so you can tell how hard the brakes are applied? Again, not that I'm aware of. ABS systems use wheel speed sensors to tell if a wheel is locked up, but that's not an absolute measurement. It's a comparative one -- relative to the other wheels.
Old Jan 29, 2002 | 10:11 PM
Default Re: Is there a such thing as a brake angle monitor? (bob01721)
Yeah, I'm looking for something closer to the latter. I'd just like to see how much I've got the brakes down so I can improve my driving techniques. I've already got a throttle angle monitor.
Old Jan 30, 2002 | 08:21 AM
Geezer's Avatar
How 'bout something like this?
Check it out here: http://www.pitstopusa.com/BRAKEPRESSUREGAUGES.asp
Old Jan 30, 2002 | 12:47 PM
Default Re: Is there a such thing as a brake angle monitor? (Geezer)
Hmm, well I was hoping for a digital gauge to go along with my throttle angle monitor, but I think this'll do basically the same thing. Thanks!
lightsleeper
Honda Civic (2006 - 2015)
20
May 30, 2012 06:22 PM
Civic_07
Suspension & Brakes
May 5, 2008 09:31 PM
lude98SH
Dec 2, 2006 09:24 AM
92ehatch
Mar 23, 2006 07:06 PM
mikeds122
Sep 25, 2004 12:55 PM
