spc problem
Old Apr 12, 2005 | 07:57 PM
budget's Avatar
Default spc problem
just intalled my spc camber kit in the rear. my caber was about negative 2.35 on the right and negative 2.45 on the right. so when i re-installed everything i adjusted the top bolt a lil bit on each side to compensate for the -2.35/-2.45 before i go get the allignment, but now when im driving it feels like the back end has a mind of its own, it feels like its fishtailing.
i thought since i kinda corrected some of the negative camber it would drive better?
since i did this is the toe way off or something!? please helpppp!
Old Apr 12, 2005 | 08:06 PM
ABK's Avatar
ABK
Default Re: spc problem (ratboy)
yeah your toe is fucked, get it allighned properly. you are dog tracking
Old Apr 12, 2005 | 08:42 PM
budget's Avatar
alright cool, so the toe is the only thing that could cause it to feel like this? i finished the install pretty late tonight so i couldnt go get the allignment done
Old Apr 12, 2005 | 08:43 PM
ABK's Avatar
ABK
Default Re: (ratboy)
well your camber could cause a pull also. Either way get an alighment done.
Old Apr 12, 2005 | 10:15 PM
budget's Avatar
Default Re: (ABK)
so after the allignment it'll be all good right?
Old Apr 13, 2005 | 03:54 AM
azn6915's Avatar
yes. my car did the same thing when i had bad toe and camber. it felt like the back end wanted to go where it felt like. once you get it fixed it shoud be good to go.
TOO MUCH TORQUE
Suspension & Brakes
Aug 14, 2010 08:59 AM
garyc17
Apr 17, 2008 08:38 AM
budget
Suspension & Brakes
Apr 13, 2005 02:54 PM
Caveman74
17
Feb 21, 2004 09:32 AM
