Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Why is my front sway bar "squeaking"??
Old Jan 29, 2002 | 02:25 PM
hondachick81's Avatar
Default Why is my front sway bar "squeaking"??
If any one could please help me on this....thanks
https://honda-tech.com/zerothread?id=121139
Old Jan 29, 2002 | 03:06 PM
getfast's Avatar
Default Re: Why is my front sway bar "squeaking"?? (civicgirl114)
If it is an ST bar, it most likely came with poly bushings, which will squeek like hell unless lubricated every so often. Although this requires some disassembly, it's time well spent for this exact reason. I usually do mine twice a year.
I'm not sure what ST (or ES) recommends, but white moly and/or graphite grease applied sloppily with an old paintbrush have both worked well for me in the past, with no visible bushing degradation over time.
Hope that helps,
Jon
Old Jan 29, 2002 | 05:11 PM
ITR764's Avatar
Default Re: Why is my front sway bar "squeaking"?? (JonSE-R)
yeap
Old Jan 29, 2002 | 05:21 PM
MaddMatt's Avatar
Default Re: Why is my front sway bar "squeaking"?? (ITR764)
What they said. The poly bushings I have squeak like a ****.
Old Jan 29, 2002 | 05:38 PM
4doorH22's Avatar
Default Re: Why is my front sway bar "squeaking"?? (MaddMatt)
My S/T bar came with white moly. Apply liberally where there is bushing-to-metal contact (especially the inside of the "D" bushing where the bar sits) and there should be no squeaks.
Old Jan 30, 2002 | 04:05 AM
Default Re: Why is my front sway bar "squeaking"?? (4doorH22)
so I need to lube.....yeah, the kit came with lube and I used it on the D bushings...but it didn't say anything about the endlink bushings...and I was thinking about doing it anyways...but didn't cause I wasn't sure!
yeah thanks Karl..."mr. I've installed sway bars before" LOL jk
Its definately worth the time to take it slightly apart to fix the squeak....it really makes sense now. THANKS!!!
swizz977
Suspension & Brakes
25
Aug 2, 2012 11:27 AM
96romaEK
Suspension & Brakes
26
Apr 16, 2010 03:25 PM
energ3tic2
Northern California (Sales)
Apr 17, 2007 12:53 PM
Bewkrazed
Jul 1, 2004 02:18 PM
DeSolMan007
Apr 7, 2003 08:22 PM
