how do you know if you have bad shifter cables?
Old Apr 12, 2005 | 07:54 PM
Inextricabledrvr's Avatar
Default how do you know if you have bad shifter cables?
Just what the title says. How would you know if they were damaged or worned etc?
well, my car as of right now is stopped in front of my house due to it being stuck in 3rd gear. I can move the shifter up and down without engaging the clutch and feels like there is no gear there. Nothing at all and i it will not move left to right or even go in neutral.
thanks
Modified by Inextricabledrvr at 12:27 AM 4/13/2005
Old Apr 12, 2005 | 09:42 PM
951dc5's Avatar
Default Re: how do you know if you have bad shifter cables? (Inextricabledrvr)
By looking at it...
Old Apr 12, 2005 | 10:27 PM
Rad Racing's Avatar
Bart Taylor Look-alike
Are you asking out of curiosity or because something is wrong with shifter/tranny etc.?
Old Apr 13, 2005 | 09:51 AM
high_revs's Avatar
could be a bad syncro or something...im not really a tranny guy...
Old Apr 13, 2005 | 09:56 AM
.H22 POWER.'s Avatar
Default Re: (h23 killa)
Syncro would be if its always popping out of gear. Syncro is what hear in place so it doesnt slip out.
Drive your car along at about 45 in 4th gear, then downshift into 3rd. When you let go of the clutch, does it stay in gear, or does it make a dirty grinding noise and pop out of 3rd?
Try this, if it pops out im pretty sure its your syncro. Maybe T/O bearing?
Thats all i can help you with bro, good luck.
Old Apr 13, 2005 | 10:02 AM
IHateJDM's Avatar
Default Re: (.H22 POWER.)
try to move the lever on the tranny by hand (where the cable connects to). If it doesn't move, then take the cable off the lever and try again. If it moves the second time, then it's the cable. If not, then its in the tranny.
knight_kidD
Jan 5, 2008 10:45 PM
5Point7Liter
Mar 16, 2007 07:52 AM
LBSU.EX
Aug 31, 2003 05:26 PM
tensai
Oct 26, 2001 10:40 PM
