Need help with JDM B16 in CRX
Old Apr 12, 2005 | 07:35 PM
Friedenreich686's Avatar
Default Need help with JDM B16 in CRX
I drive a 1990 CRX HF with a JDM B16 its been running fine up until about a week ago. I haven't changed anything and out of nowhere my car it starting to bog out. Pretty much it only happens when I'm doing just normal driving, when I get up to about 3000rmp's to 5000rpm's my car bog's, it doesn't want to accelerate normal unless I floor it. Because of this problem I have recently changed my spark plugs, wires, rotor, cap and fuel filter. But none of this helped. One person has suggested changing or upgrading my injectors, and another person has suggested a fuel pump regulator (to turn up the amount of fuel I am getting because maybe I not getting enough). Has anyone else had this problem or have any suggestions on what it might be, if so please help.
Old Apr 12, 2005 | 07:50 PM
Burntrubber87's Avatar
Default Re: Need help with JDM B16 in CRX (Friedenreich686)
Is your ECU throwing any codes? Could very well be your O2 sensor, also.
Old Apr 12, 2005 | 07:56 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: Need help with JDM B16 in CRX (Burntrubber87)
https://honda-tech.com/zerothread?id=637661
Read about O2 sensor wiring..
Old Apr 12, 2005 | 08:30 PM
Default Re: Need help with JDM B16 in CRX (88DXCRX)
where can I read about O2 sensors? And I dont want to sound like an idiot but I am just learning about this stuff so how do I read ECU code or where can I go to learn about it?
sir4doorking
Nov 24, 2007 07:57 AM
looxs
May 17, 2007 10:36 PM
b6teened91
Feb 28, 2007 10:13 AM
Friedenreich686
May 7, 2005 08:48 AM
JDM CRX
Apr 7, 2003 09:54 AM
