FS: Jdm ITR motor 1600obo
Old Apr 12, 2005 | 04:52 PM
Fuzion's Avatar
Default FS: Jdm ITR motor NEW PRICE 1500obo
24-27k ON BLOCK!!!!!!!
98 jdm itr bottom end[bottom end painted gold] (includes crank, rods, pistons, crank pulley, alternator, complete oil pan stuff, it is missing the locking key for the crank pulley so it's not 100% assembled, but the rest of the rotating assembly is in of course.)
brand new timing belt
brand new water pump
brand new oil pump gear
1st gen b16 head and intake manifold (comes with all internals and black valve cover, 2 cam holder bolts are broken but will easily be removed with an easy-out screw remover from home depot(theyre like 10$), also 1 threaded distributor bolt hole cracked and cannot be used, but the other 2 bolt holes are perfectly fine.)
alternator attached
brand new AEBS headstuds
brand new headgasket
brand new crank pulley bolt
some brand new seals in the head(not valve seals)
no miles on motor since head was put on
1500obo
you can call me cause i dont use the comp very often 571-330-5857 name is Tamarr
will part for the right price .
SINCE ASSEMBLED WITH NEW PARTS HAS NOT BEEN INSTALLED OR STARTED SINCE MINOR REBUILD.
Modified by Fuzion at 6:21 PM 4/15/2005
Modified by Fuzion at 6:22 PM 4/15/2005
Modified by Fuzion at 11:27 PM 4/16/2005
Modified by Fuzion at 3:12 PM 4/25/2005
Fuzion
May 8, 2005 06:47 PM
Fuzion
Apr 25, 2005 11:22 AM
Fuzion
Apr 21, 2005 08:19 PM
