205/50/15 or 195/50/15 ?
Old Apr 12, 2005 | 01:28 PM
garaged_Si's Avatar
Default 205/50/15 or 195/50/15 ?
-i'm deciding whether to get these tires or not, the problem with the 205 tire is that i'm afraid that it will rub because i have H&R race springs on my EM1. does anybody have the same setup as mine and sporting 205's tire? Thanks.
-Somebody selling the 195/50/15yokohama AVS es100 (4)brand new, has the stickers on it for $250 <<---- is this a good deal? or a Nitto NT450 205/50/15 same condition (brand new,4) $220.
Thanks For the response.
Old Apr 12, 2005 | 02:19 PM
garaged_Si's Avatar
Default Re: 205/50/15 or 195/50/15 ? (garaged_Si)
anybody??
Old Apr 12, 2005 | 02:31 PM
electronb16si's Avatar
I rocked 205/50/15 azenis and es100's on my si on H&R race springs and its is VERY close to rubbing. As long as you and your passengers aren't 250+ lbs each you will be alright. Be prepared to get your fender liners ripped out though.
Old Apr 12, 2005 | 06:03 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (electronb16si)
I run 195/50R15 on my 4th gen fits nice and imo I rather a better tire *teh yoko* then those nittos anyway
Old Apr 12, 2005 | 07:19 PM
UncleD's Avatar
Default Re: (Ace$nyper)
I would run the 195's if I were you. I don't really like 205's on civics....I think they look like a Super Swamper or somethin. I don't like Nitto either....even though Toyo owns Nitto, a <U>love</U> Toyo's, but the Nitto's are all hype. Yokohama ES100's seem to be a pretty decent tire, go with those.
Old Apr 12, 2005 | 11:19 PM
madtownhonda's Avatar
Get the ES100s just because it's a better tire.
205/50 is the correct size...looks best IMO.
I have 205/50 azenis on one set of wheels and 195/50 T1S on my other wheels. Tires should be about grip anyways.
Rubbing has a lot to do with offset as well. If you have the correct offset, it shouldn't rub.
Old Apr 14, 2005 | 09:37 AM
jung4g's Avatar
Default Re: 205/50/15 or 195/50/15 ? (madtownhonda)
The es100s are horrible in my experience. They are hard, flexy, and they wear badly. AS for tire size, there are a couple factors to consider: weight, effective gearing, and rim size. If you have 15x6.5 (as most wheels are), you may prefer the 195s. This will have a sligthly lower gearing as the overall tire is smaller, the little bit less rubber does make a difference though, as every bit helps. The 205s are a little better suited to a 15x7 wheel, but I've ran them fine on 15x6.5 as well as many others. The actual size can vary by manufacturer and model, so beware of actual specs as well. If you are seriously consider the 450s and es100s, I guess my efforts are in vane, as both of those are crappy street tires. If you want any respect and performance, get descent tires, the Toyo T1s is available in both sizes and are very light weight, for street I'd suggest those. Sadly the older and superior AVS intermediates were discontinued, or I'd say get those. Those prices may seem cheap, but I'd wouldn't run those tires unless they were free. And then only for my commuter.
Old Apr 14, 2005 | 07:44 PM
siblue_gzer's Avatar
i wouldn't prefer the nitto 450. i have 205/40r/16 on my rota's and they have no grip in the rain and even dry roads, the handling sucks. i never experienced the yoko's, but i would go with yoko's.
Old Apr 14, 2005 | 10:53 PM
LSturbointeg's Avatar
stick with the 195's...
Old Apr 17, 2005 | 02:08 PM
gakkuken's Avatar
if your car is too low or low enough, you are better off w/ 195
Old Apr 17, 2005 | 08:16 PM
c_mack9's Avatar
i have h&r springs with agx struts with 205/50/15 tires and they DO rup the fender liners on the driver side. im not fat, only weigh 145 but even when a passenger is wiht me their side dont rub, just the drivers side. hope this helps
jap lowrider
Nov 15, 2011 07:28 AM
PreyStayShun
Mar 7, 2011 01:20 PM
lmndc4
Mar 22, 2010 09:33 PM
Mischiefek
Nov 6, 2004 08:54 AM
