idle problem (sirII b16a in a 92 cx)..throws code, but no code found
Old Apr 12, 2005 | 12:46 PM
Grip's Avatar
Default idle problem (sirII b16a in a 92 cx)..throws code, but no code found
i have a b16a sir2 in my 92 cx...once the motor warms up the idel surges between 900 rpm and 1200 rpm...it also throws a code...but when i check the code no code appears...what is the problem?..i thought it was the IACV but recent search's show that a faulty IACV would show diffrent symptoms..any idea's?
Old Apr 12, 2005 | 12:47 PM
Grip's Avatar
Default Re: idle problem (sirII b16a in a 92 cx)..throws code, but no code found (Grip)
ecu is a virgin jdm p30
LShatchie's Avatar
It could be the tps.
Old Apr 12, 2005 | 12:58 PM
Grip's Avatar
Default Re: idle problem (LShatchie)
how do i check the TPS to see if its working or not?
Old Apr 12, 2005 | 03:22 PM
LShatchie's Avatar
Default Re: idle problem (Grip)
Before I say anthing else, you say you have a code, but when you check it none appears. Are you checking it properly by jumping the jumper plug with a paperclip?
Old Apr 14, 2005 | 02:39 PM
Grip's Avatar
yes i jump the code usig a paper clip and the jumper harness
TheHatchHog
16
May 15, 2003 11:26 AM
Hondasaurs
Sep 20, 2002 03:19 AM
