OBD1 GSR into an EF
Old Apr 12, 2005 | 11:46 AM
asmallsol's Avatar
Default OBD1 GSR into an EF
Right now, I have a 95 del sol with a 2ng gen (95) GSR swap. I was about to sell it for a car with more room, and then put it in a ditch on a snowy day, bending the driverside frame rail. So now, I am probally going to buy another honda and swap my engine into an EF.
Here is what I have...
GSR engine swap w/ hydro tranny
obd1 p72 ECU
GSR engine harness
GSR axles and intermediate shaft
OEM intake manifold
GSR Throttle cable
I want to buy as little as possible when I do this swap.
Things that I know that I need to buy
the cable->hydrolic mount kit
Hasport linkages (or shorten 2nd gen integra linkages)
OBD0-1 ECU wire harness
What else will I need?
Can I use my (3rd gen teg) axles if I use my hydro tranny?
Other then the length diffrence, will my OEM exhaust manifold work?
Raditor hoses I can figure out.
Can I use the stock EF's knuckles?
Old Apr 12, 2005 | 11:49 AM
EP3_05's Avatar
Default Re: OBD1 GSR into an EF (asmallsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asmallsol &raquo;</TD></TR><TR><TD CLASS="quote">
Can I use the stock EF's knuckles?</TD></TR></TABLE>
Yes as long as you have an EF with Si/dx hubs
The OEM exhaust manifold will be ok except the ground clearance isn't that great.
You can use stock EF knuckles/hubs if you start with an Si or Dx model.
Old Apr 12, 2005 | 12:28 PM
Rywire's Avatar
http://www.droppedcrxsi.com has it all man, wiring from rywire, and a how to with parts list.\
Ryan
Cripton805
May 25, 2010 09:37 AM
Dr1ft1ng0wns
Apr 4, 2010 09:15 AM
d.fleezy
Oct 16, 2008 06:17 AM
ELSUICIDA
Apr 25, 2007 05:19 PM
91 HONDAsaurus rex
Aug 26, 2004 08:51 PM
