Question about power door lock relays
Old Apr 12, 2005 | 10:33 AM
dxhatch93's Avatar
Default Question about power door lock relays
I have a viper 791 alarm installed with power door locks but the power door locks dont have enough power to lock the doors. I went to radioshack and bought 2 relays. I dont know much about relays but on the box it says 30-amp auto relay SPST and it has 4 prongs. Will these relays give the door locks enough power?
Old Apr 12, 2005 | 03:54 PM
matt_in_sd's Avatar
Default Re: Question about power door lock relays (dxhatch93)
No! All relays do is make or break a connection. They dont add power. The rating is to let you know how big a load you can switch without melting the relay. For example the relay for headlights only need to switch about 6 amps, so a relay rated for 10 amps is adequate, if you have 1 relay per light. If you use 1 relay for 2 lights then you need a relay rated for 20 amps. If your pl are oem then something is binding. If the pl are aftermarket they could be undersized.
Old Apr 12, 2005 | 05:02 PM
dxhatch93's Avatar
Default Re: Question about power door lock relays (matt_in_sd)
cool thanks, i just realized i needed 5 prong relays
Old Apr 13, 2005 | 09:14 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxhatch93 &raquo;</TD></TR><TR><TD CLASS="quote">I have a viper 791 alarm installed with power door locks but the power door locks dont have enough power to lock the doors. I went to radioshack and bought 2 relays. I dont know much about relays but on the box it says 30-amp auto relay SPST and it has 4 prongs. Will these relays give the door locks enough power? </TD></TR></TABLE>Need info...... are they OEM doorlocks, or are they aftermarket? If they are OEM, do the doorlock switchs on the doors work? Did the doorlocks ever work? If they are aftermarket, you will need 2- 20/30 amp SPDT relays, [most commonly used] to wire them go to http://www.the12volt.com scroll down to car security, click on doorlocks, scroll down to add actuator (s) click on diagram 94
Old Apr 13, 2005 | 08:37 PM
CarAudioPro's Avatar
Default Re: Question about power door lock relays (fcm)
you got the wrong relays, you need SPDT relays. not SPST. they should have 5 prongs not four.
wes7side5o
Jul 23, 2010 08:22 AM
CleanDC4
Apr 21, 2006 10:49 AM
jisu009
Audio / Security / Video
Jan 28, 2005 12:36 PM
Back in Black
Jul 7, 2002 12:27 PM
