Compression Numbers Okay? Built B20vtec w/ 12.5-1 compression ratio
Just did a compression test on B20vtec, I got 200 all the way across. I haven't drove the car more than a mile, mainly have just started it up and that's it. Do these numbers sound okay considering it hasn't been broken in completely? Or are they a little low considering I should be running close to 12.5-1 compression? And what compression test number do car with this type of compression generally lay down when fully broken in? Thanks, just trying to get an idea
they're all the same. Thats good. Also your compression #'s may go up as the rings seat.
Modified by 97L-esVeeTeg at 12:02 PM 4/12/2005
builtprelude
Jan 22, 2004 10:49 PM
