HELP! Just got a ALPINE DVA-5200
Old Apr 12, 2005 | 06:03 AM
TurboEG6's Avatar
Default HELP! Just got a ALPINE DVA-5200
I received my Alpine DVA-5200 (DVD/VideoCD/CD player). It came with everything in the box but the product obviously was used. My question is, Anyone here have a pic of the POWER wires that it is supposed to come with?
The ones I got are Orange, Yellow, and Black. But on the instructions, it seems like it is missing 1 more wire AND it also lists different colors.
PLEASE HELP!
Old Apr 12, 2005 | 07:37 AM
fcm's Avatar
fcm
Old Fart
Default Re: HELP! Just got a ALPINE DVA-5200 (TurboEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I received my Alpine DVA-5200 (DVD/VideoCD/CD player). It came with everything in the box but the product obviously was used. My question is, Anyone here have a pic of the POWER wires that it is supposed to come with?
PLEASE HELP! </TD></TR></TABLE> Orange is illumination, yellow is constant power, and black is ground, you seem to be missing more then one more, red - acc., blue. and blue/white - power ant. and amp trigger leads, maybe yellow/black and yellow/red - brake and E-brake maybe a pink - mute and speaker wires, is there not another harness on the offboard "switcher" box? 94
Old Apr 12, 2005 | 07:43 AM
TurboEG6's Avatar
Default Re: HELP! Just got a ALPINE DVA-5200 (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> Orange is illumination, yellow is constant power, and black is ground, you seem to be missing more then one more, red - acc., blue. and blue/white - power ant. and amp trigger leads, maybe yellow/black and yellow/red - brake and E-brake maybe a pink - mute and speaker wires, is there not another harness on the offboard "switcher" box? 94</TD></TR></TABLE>
This is for the DVD unit, uhmm...I am talking about the 4pin plug on the back of this unit and that it only came w/ those 3 wires. I had attached the AI-Net cable since I have a CVA head unit w/ monitor and the Yellow Video cable as well. I then plugged the Yellow for Power and Black wire for ground. Didn't connect the orange cuz it was just for illumination. But ARE these the 3 correct wires used with this UNIT? So confused!
Old Apr 12, 2005 | 07:55 AM
fcm's Avatar
fcm
Old Fart
This is for the DVD unit, uhmm...I am talking about the 4pin plug on the back of this unit and that it only came w/ those 3 wires. I had attached the AI-Net cable since I have a CVA head unit w/ monitor and the Yellow Video cable as well. I then plugged the Yellow for Power and Black wire for ground. Didn't connect the orange cuz it was just for illumination. But ARE these the 3 correct wires used with this UNIT? So confused! </TD></TR></TABLE>Yea sorry, thought you also had the optional digital processor, but you are using a CVA HU so the only plug will be the 4 pin, and you should have all the wires you need, black,yellow and orange, the acc. comes from the CVA HU, so what is happening, or not happening? 94
Old Apr 12, 2005 | 08:14 AM
TurboEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote">Yea sorry, thought you also had the optional digital processor, but you are using a CVA HU so the only plug will be the 4 pin, and you should have all the wires you need, black,yellow and orange, the acc. comes from the CVA HU, so what is happening, or not happening? 94</TD></TR></TABLE>
I just wanted to verify if I had received the correct power wires. Well here's the situation, I hooked up the AI-Net from the DVA to my CVA-1005 brain. Then I hooked up the Video cable from the DVA to the CVA AUX1. Then connected the power(Yellow wire) & Ground. Turned on my CVA and changed it to the DVD source and what I got was NO video feed & Choppy sound. What else do I need to do?
Old Apr 13, 2005 | 07:46 AM
fcm's Avatar
fcm
Old Fart
I just wanted to verify if I had received the correct power wires. Well here's the situation, I hooked up the AI-Net from the DVA to my CVA-1005 brain. Then I hooked up the Video cable from the DVA to the CVA AUX1. Then connected the power(Yellow wire) & Ground. Turned on my CVA and changed it to the DVD source and what I got was NO video feed & Choppy sound. What else do I need to do?</TD></TR></TABLE>It sounds like you need to take it back and get your money back, it sounds hooped 94
Old Apr 15, 2005 | 07:58 PM
idriveadelsol7's Avatar
NEVER buy used audio equipment. and "REFURBiSHED" means some **** happened to it to cause it from functioning correctly. check this out for an example... even though it's "fixed" why do cars carry "accident" titles even thought they've been "fixed"? go figure.
CRex_22
10
Jun 4, 2008 07:33 AM
all_motor
12
Dec 23, 2005 04:31 AM
1990hondadx
Audio / Security / Video
Aug 8, 2004 09:48 AM
97civic123
Mar 28, 2004 06:54 AM
JsCvCVtechSI
Mar 17, 2004 12:35 PM
