Hyperco Hydraulic Spring Perches - anyone using these things?
Old Apr 12, 2005 | 05:55 AM
Kengs's Avatar
Default Hyperco Hydraulic Spring Perches - anyone using these things?
So I'm flipping thru a recent issue of Racecar Engineering, and I see the ad for these things:
http://www.hypercoils.com/Prod....aspx
The Hyperco/ICP Hydraulic Load Centering Spring Perches substantially improve performance by allowing the spring forces to remain centered on the shock. By precise shaping of the sealing wall of both the perch and cylinder body, the perch can freely tilt as needed to evenly distribute the load of the spring. The result, a reduction of bending load on the shock absorber of up to 96% along with an enhancement in mechanical grip at the tire.
Is it something you would only notice on a racecar? So do they replace the existing perch(es)?
*** EEEK, do they even have a Honda application? ***
I think I should just go back to bed
Modified by Kengs the "OG" JDM Junkie at 2:05 PM 4/12/2005
Old Apr 12, 2005 | 07:07 AM
01-0720's Avatar
Default Re: Hyperco Hydraulic Spring Perches - anyone using these things? (Kengs the "OG" JDM Junkie)
looks like a good product to me, it also doesnt sound like it whould cost a grip so someone on here will have it soon and will give a review i hope
Old Apr 12, 2005 | 12:16 PM
ZygSpeed's Avatar
There was some discussion about this/these in the roadrace forum a few weeks ago, and the consensus was that it would/might at best only be beneficial in a true race car (F Atlantic, Indy Car, etc.) suspension where this last bit of compliance/adjustment would actually make a difference.
After all, you did say you saw this in <U>Racecar Engineering</U> magazine.
jdmwannabe813
Suspension & Brakes
Jan 3, 2012 10:29 PM
exgr
18
Oct 29, 2010 02:14 PM
Understeer
71
Dec 19, 2007 08:57 AM
riceforlife
Suspension & Brakes
Dec 18, 2007 05:10 AM
Fuel
May 3, 2004 01:25 AM
