ST rear sway+tie bar combo w/ stock lca's?
Old Apr 11, 2005 | 11:59 PM
2-7offsuit's Avatar
Default ST rear sway+tie bar combo w/ stock lca's?
Like the title says, will the ST sway with tie bar combo work with the stock '92 lca's (no stock sway)? Thanks.
Old Apr 12, 2005 | 12:02 AM
eg6sir-s's Avatar
Default Re: ST rear sway+tie bar combo w/ stock lca's? (2-7offsuit)
call http://www.stracing.com in the morning and findout or just browse throught their website.
Old Apr 12, 2005 | 12:03 AM
matto23's Avatar
i imagine the endlinks must mounts to something. therefore, I am near certain you need integra LCA's... better wait til someone else posts though
Old Apr 12, 2005 | 10:11 AM
2-7offsuit's Avatar
Come on I know a lot of people has this setup...
Old Apr 12, 2005 | 10:18 AM
ironlung78's Avatar
Default Re: (2-7offsuit)
i'm pretty sure Suspension Techniques mounts in the same place as your shock and not in a separate location like 99-00 civic
Old Apr 12, 2005 | 10:21 AM
POE's Avatar
POE
i dont have the ST lower tie bar but i have the rear sway bar, and it mounts infront of the shock with an L bracket. it doesnt mount to the LCA. i drive a 94 civic dx coupe.
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (POE)
Just get the LCA's and get a normal sway bar. They are cheap enough.
Old Apr 12, 2005 | 11:16 AM
ironlung78's Avatar
Default Re: (sidesi)
if you already have an exhaust make sure you ask around to see if it will fit with that bar. i've read more than once that the new bar will hit your exhaust piping, so you end up thinking you did a good thing by adding the sway, but you get that not so friendly reminder everytime you hit a bump and you hear a clunk
Old Apr 12, 2005 | 11:37 AM
2-7offsuit's Avatar
Thanks, I have the Apexi WS, which has pretty small piping and doesn't come out at any crazy angle. Think that should be a problem?
POE what kind of exhaust do you have? Any problems with it?
Old Apr 12, 2005 | 11:47 AM
POE's Avatar
POE
i have 2.5 inch mandrel bent piping, no problems at all.
Old Apr 12, 2005 | 11:48 AM
POE's Avatar
POE
Default Re: (POE)
Old Apr 12, 2005 | 11:55 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sidesi &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty sure Suspension Techniques mounts in the same place as your shock and not in a separate location like 99-00 civic</TD></TR></TABLE>
Truth. You don't need special LCAs for the ST bars.
Old Apr 12, 2005 | 11:57 AM
POE's Avatar
POE
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Truth. You don't need special LCAs for the ST bars.</TD></TR></TABLE>
word, they dont mont to the lca, they mount infront of the shock with an L bracket
Old Apr 12, 2005 | 12:03 PM
2-7offsuit's Avatar
Yeah, that's what I thought. I just wanted to make sure that the sway/tie bar combo didn't mount differently.
Old Apr 12, 2005 | 04:20 PM
2-7offsuit's Avatar
I ended up just ordering the normal st rear sway. POE, what kind of tie bar do you have?
Old Apr 13, 2005 | 11:25 AM
2-7offsuit's Avatar
Is there any drilling required to install the ST rear sway?
Old Apr 13, 2005 | 11:31 AM
matto23's Avatar
i have heard yes.
btw, sorry for the mis-info earlier.
Old Apr 13, 2005 | 11:39 AM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2-7offsuit &raquo;</TD></TR><TR><TD CLASS="quote">Is there any drilling required to install the ST rear sway?</TD></TR></TABLE>
You have to enlarge some holes in the subframe, but I didn't have to cut any completely new ones. Getting the nuts and bolts in there is a huge pain in the ***. I highly suggest having the LCA completely removed when you do so.
Old Apr 13, 2005 | 11:58 AM
POE's Avatar
POE
yeah u just have to engarge 4 holes that are allready in the subframe like this man said ^^^^
Old Apr 13, 2005 | 06:39 PM
2-7offsuit's Avatar
Any idea what size drill bit needs to be used? I'm sure the directions with the bar will say, but I'd like to have everything in order before it gets here.
BTW- Thanks, you guys have been a big help.
Old Apr 18, 2005 | 11:17 PM
2-7offsuit's Avatar
bar showed up today. Anyone have a pic of the holes that need to be enlarged? Or a suggestion on the best way to do it?
Old Apr 19, 2005 | 01:45 AM
AGENT 99's Avatar
Interested in this as well.
Old Apr 19, 2005 | 05:16 AM
jdm-94dc2's Avatar
do those sway bars make a difference in cornering
Old Apr 20, 2005 | 12:43 PM
2-7offsuit's Avatar
Default Re: (TOPSHOTTA-93eg6)
That's the idea, but I couldn't tell you for sure because I haven't installed it yet.
Old Apr 20, 2005 | 12:56 PM
matto23's Avatar
yes, they help cornering and high speed manuvering. i have a JDM ITR 23mm rear bar on my GSR i love it, and with 17's and omnipower full coils, I was oversteering through traffic light left turns, it was soooo fun, but i got cocky on a onramp once and swiped out. not so bad, i just messed up my rims and bent my trailing arms, i had the car running the very next day, at the expense of my wheels, and 250 for new trailing arms, install was done by yours truely. sorry for the blog/vent/treadjack. just thought i would share my experience.
