What you think is the problem?
Old Apr 11, 2005 | 09:36 PM
JDM RHD eg6's Avatar
Default What you think is the problem?
ok i have a 1991 honda crx si
d15b longblock with crx si tranny and crx si obd-0 engine harness with the intake manifold and injectors, I just got the obd-0 to obd-1 ecu harness. and now im going to be picking up a vtec p28 or p08 ecu soon and im using the obd-1 d15 dizzy with the obd-0 plug? you think im missiing anything?
heres the obdj-1 d15b dizzy with the obd-0 pulgs
Old Apr 11, 2005 | 09:44 PM
Default Re: What you think is the problem? (MrEF8)
Old Apr 12, 2005 | 02:24 AM
96-EJ6 B18C's Avatar
You'll have to install the OBDI distributor at the same time as the OBDI ECU, but other than that I think your set.
Old Apr 12, 2005 | 06:22 AM
SETI20's Avatar
The harness comes with instructions.
Get your hands on the OBD1 receptacle plugs just like the ones that are on your dizzy. Re-pin it and you're set.
Or you can use your old obd-0 plugs. But the obd1 ones are prettier to look at.
Pancho2193
Mar 2, 2013 06:35 AM
cwf1988
Jan 3, 2009 02:11 AM
DCRB
Sep 19, 2008 07:23 AM
Cractos
Aug 12, 2004 06:36 PM
