**Updated** Cleaning out shop sale..tons of parts!(trades?)
Old Apr 11, 2005 | 09:01 PM
JDMotive's Avatar
Default **Updated** Cleaning out shop sale..tons of parts!(trades?)
All Prices are OBO/Negotiable...will make package deals.....All trades considered..(wheels,stereo equip,92-95 eg parts,electronics,etc..)
Just make an offer!! My shop is small enough..cant keep all of this stuff!
heads/parts
-'97 B18c1 Integra GSR head..complete and in excellent condition..includes intake manifold,injectors,rail,throttle body,valve cover..everything under valve cover(all valvetrain,cams,etc..)-Asking $450
-1st gen Ported B16a intake manifold-$60
-Ported and polished 2003 Civic si K20a3 head,no intake manifold,missing 4 valves/springs but otherwise perfect-$150
-Stock B16a cam gears-$15
-Stock B16a fuel rail-$15
-Stock B18b cams w/gears-$30
-Stock RSX type S fuel rail and injectors-$40
blocks
-2003 RSX type S K20a2 short block..no oil pan,2 rods/pistons are out of block(still have them)..everything is in good condition-$200
-'94 Civic cx d15b8 short block..complete and perfect condition-$100
-'97 Acura TL C32a2 engine..pretty much complete-$200
transmissions/parts
-'03 Base Rsx k20a3 5 speed transmission-$400
-'03 RSX type S 6 speed transmission w/ type R 4.7 final drive-$800
-(2)'97 Civic DX manual transmissions..both work,but need input shaft bearings-$30 each
-'90 Civic std manual transmission-$75
-'97 Civic ex shift linkage-$40
-Stock K20a2 flywheel-$40
-Stock B16a3 flywheel-$30
-Stock D16z6 flywheel-$20
-Stock D15b8 flywheel-$20
-Stock D16y8 flywheel-$25
-Stock b16a differential-$30
-'97 Civic ex rear L bracket-$20
-'90 Civic/crx rear manual transmission mount bracket-$10
ecu's
-RSX type S K20a2 PRB ecu with paperwork(to match immobilizer)-$150
-'99 Civic si b16a2 P2T manual ecu-$80
-'93 Civic cx p05 ecu-$30
suspension
-'90-'93 Integra LS front spindles/hubs-$40
-'90 Civic Dx front spindles w/brakes-$50
-'99 Civic Dx front spindles w/brakes $50
-Stock crx/civic Dx springs and shocks front and rear-$30
engine/tranny mounts
-AVID H22 mounts for 92-95 civic/94-01 Integra-$125(no rear mount)
-Hasport rear drag mount for civic/crx b16a swap-$50
-Stock '97 Civic ex drivers side engine mount w/bracket-$30
-Stock '97 Civic Ex rear mount-$30
-Stock '00 type R a/c bracket/vibration mount-$35
misc
Set of four (4) Stock K24a Crv pistons(87mm)..decent condition-$40
-Gsr b18c1 throttle body,excellent condition,no map or tps-$40
-LS b18a throttle body,no tps-$35
-'93 Civic Cx exhaust manifold w/downpipe..great for diy turbo kits-$40
-'92-'95 Civic Manual pedal assembly-$40
-'92-'95 Civic master cylinder-$25
-'91 Civic Dx Auto pedal assembly...throttle and brake pedal w/brackets and mounts-$30
-'97 Civic Ex D16y8 distributor-$80
-(2) B18a ls valve covers..one is stock,other is painted red-$15 each
-'03 RSX type S a/c compressor-perfect-$70
-'99 Si B16a2 a/c compressor-good condition-$50
-'00 Type r b18c5 a/c compressor-good condition-$50
-03 RSX type S power steering pump..perfect-$50
-Del sol tail lights-$40
-Del sol removable top-$60
-Del sol doors w/power windows-$100 each...perfect condition
-Del sol front windshield in perfect condition-$60
Pictures available upon request...too much to take all at once.
Old Apr 13, 2005 | 06:28 PM
JDMotive's Avatar
Default Re: **Updated** Cleaning out shop sale..tons of parts!(trades?) (JDMotive)
Old Apr 13, 2005 | 11:04 PM
JDMotive's Avatar
somebody need anything at all?
Old Apr 14, 2005 | 08:32 AM
JDMotive's Avatar
Old Apr 15, 2005 | 08:39 AM
JDMotive's Avatar
bump!
Old Apr 17, 2005 | 08:58 AM
JDMotive's Avatar
All prices are negotiable and I will accept trades...
Wheels,PSP games,car audio etc...
JDMotive
May 9, 2005 03:33 PM
JDMotive
Apr 8, 2005 10:46 AM
CW-ITR-329
May 29, 2003 02:20 PM
