Timing belt noises?
Old Apr 11, 2005 | 07:52 PM
flat-blk-HB's Avatar
Default Timing belt noises?
I have heard that timing belts can make noise when they are too tight. Is this true? The reason I ask is my car has started making a new noise that is getting on my nerves. It seems like when it warms up it will make a damn sound like a toy car or something only under accleration not or barely noticable at idle. Also it whistles when speeding up to upshift every once in a while...Maybe its just the alternator belt of A/C belt..
How do you check to see if your belts are too tight?
Thanks
Old Apr 11, 2005 | 09:06 PM
93gsrcoupe's Avatar
Default Re: Timing belt noises? (flat-blk-HB)
My TB was too tight and it sounded like a supercharger (it made a weening noise when it accelerated). Try messing with the tensioner. It could also be your alternator or A/C which can also be easily adjusted. Sometimes cold weather causes the noises too.
Old Apr 11, 2005 | 09:11 PM
1FastCoupe's Avatar
does it sound like a pigeon got caught under the hood?
Old Apr 12, 2005 | 03:59 PM
GS-Rcivic's Avatar
Default Re: (1FastCoupe)
hmm i have that supercharger sound but i dont think its the belt. Im guessing its my LSD. How tight should the belt be then, maybe thats my problem also.
Old Apr 12, 2005 | 05:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FastCoupe &raquo;</TD></TR><TR><TD CLASS="quote">does it sound like a pigeon got caught under the hood?</TD></TR></TABLE>
Yeah actually it does...
I am going to try to mess with it tomorrow.
Old Apr 14, 2005 | 05:12 PM
1FastCoupe's Avatar
Default Re: (flat-blk-HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flat-blk-HB &raquo;</TD></TR><TR><TD CLASS="quote">
I am going to try to mess with it tomorrow.</TD></TR></TABLE>
The the belt is a little on the tight side. If you turn the crank counter clockwise with a 19mm wrench to TDC you should be able to twist the belt about half a turn on the exhaust side of the belt and almost half on the intake side...
Old Apr 17, 2005 | 06:10 AM
Thanks...I will check on that....(still being lazy and have not messed with it)
Psycho719
Sep 14, 2011 04:28 AM
NikeSB
Sep 14, 2006 04:23 PM
bam181
Aug 20, 2006 05:16 AM
mcbasspro
Apr 2, 2006 08:59 PM
ShaolinRider
Sep 24, 2003 09:27 AM
