High octane gas
Old Apr 11, 2005 | 05:38 PM
RemerLex11's Avatar
Default High octane gas
there was a thread about this a while ago but i couldn't find it.........
why is it exactly that racing gas in a stock engine will do nothing but possibly make u lose power?
Old Apr 11, 2005 | 05:55 PM
SkRiBLaH's Avatar
Default Re: High octane gas (Matt5745767)
bercerse the higher octane, all it does is resist detonation.
thats the only differance. its not filtered more or anything. thats why high compression motors need it. otherwise they would detonate and die.
Old Apr 11, 2005 | 06:24 PM
RemerLex11's Avatar
Default Re: High octane gas (SkRiBLaH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">bercerse the higher octane, all it does is resist detonation.
thats the only differance. its not filtered more or anything. thats why high compression motors need it. otherwise they would detonate and die.</TD></TR></TABLE>
so does that mean in a stock engine racing gas would take longer to detonate therefore by the time you've reached redline the gas hasent detonated enough for the pistons to make peak power?
Old Apr 12, 2005 | 05:00 AM
RemerLex11's Avatar
bump if anyone knows
Old Apr 12, 2005 | 05:13 AM
jdm123's Avatar
i dont know if this helps and i'm not trying to flame if thats what you think, but performance is gas isnt needed in stock motors and i dont think it would do anything. I think it is just for the detonation issue. I could be wrong though. I'm still learning to.
Old Apr 12, 2005 | 06:22 AM
asubennett's Avatar
Default Re: High octane gas (jdm123)
High octane gas is simply more resistant to combustion. High compresion motors have extremely high cylinder pressure high cylinder pressure places the motor in a volatile state with lower octane fuel. Becasue lower octane fuel does not resist combustion as well high cylinder pressure coupled with increased heat can combust the mixture earlier than desired in a given pistons travel. This what breaks stuff.
On a stock motor using very high octane fuel you will discover harder starts and potentially a loss of power becasue you do not have enough energy to completely combust the entire mixture.
WarpedSportzKid
Feb 8, 2007 01:11 PM
tobe1424
Mar 30, 2006 06:01 AM
JsNA99si
Jun 16, 2004 02:51 PM
Muckman
Oct 4, 2003 02:12 AM
vtec.dc2
Aug 22, 2002 02:03 PM
