My car has hella lots of miles on it.....
ok guys my odo just rolled over to 266k miles the other day....i run it hard sometimes and it still keeps on goin...i love the d16z6!!! anyways how many miles have yall got on yalls rides beofre it just went out....i bought the car in august of 04 with 256k miles on it and it had recently gotten new timing belt and water pump and all that good stuff....what kinda stuff should i forsee in the future to keep checked on after those many miles?
if this is in the worng forum please move it...i looked at the forum rules and deemed this ok for this forum
Basically the way I see it, since you've already done the major tune up (timing belt), all you need to do now is the basic tunes ups every so many miles and it should last quite a while. I would just be carefull with that many miles, it would probably be easy to throw a rod or somthing like that.
From: hittin corners so hard you can taste my rims..
im about 240K on my VX.. 1.5 D15Z1 longblock, turbo'ed with 7 PSI.
timming belt, waterpump, plugs, cap, rotor, and wires... you'll be gold more many more miles to come.
i have a 1986 accord LXi with 321K miles on it. it's been to hell and back, and now the brakes keep braking even though i do not step on the pedal. but, engine and tranny are still super strong....
Damn dude almost 300k and still kickin. nice! Yea man, just stay with basic mantinence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built B16A »</TD></TR><TR><TD CLASS="quote">im about 240K on my VX.. 1.5 D15Z1 longblock, turbo'ed with 7 PSI.
timming belt, waterpump, plugs, cap, rotor, and wires... you'll be gold more many more miles to come.</TD></TR></TABLE>
Thats just incredible.
Do you guys all have the original transmissions?
My other car (97 ls) just turned 167k and the shifter is feeling notchy and isnt as smooth as it once was
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tca0bell »</TD></TR><TR><TD CLASS="quote">dam man..i got 194k and im gettin scared already. still runnin strong.</TD></TR></TABLE>
Hell, that's nothing. My Mom's old 95 DX went for 250K with the original clutch before it and the motor went. She drove around for about a year with no oil; I'm sure it could have gone for much longer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer »</TD></TR><TR><TD CLASS="quote">
lol the reason to love your honda.
i have a 86 civic with 310k its starting to go to **** but i still beat on it all the time.
just recently relpaced axels
My D16Y8 only has 120k on it. But my GF's Bonneville has 275k on it and I just changed out the original spark plug wires a few months ago
The timing chain makes ALOT of noise..lol..original too.
I hope the HOnda outdoes the Bonneville. Only time will tell. I can tell you one thing, its going to be maintained a hell of alot better.
The timing chain makes ALOT of noise..lol..original too. I hope the HOnda outdoes the Bonneville. Only time will tell. I can tell you one thing, its going to be maintained a hell of alot better.
My D16Y8 has 95,xxx I do all the basic mantinence but I dont know how long its going to last because I drive it kinda hard. I have probably taken it to redline about 15 times since I bought the car 2 years ago with 69.xxx miles. I want to turbo it but someone told me that my mileage was too high to do so and I dont know if the engine will be able to handle it. What do I need to check to see if it can handle turbo? I heard that I could get a compression and leak test to see if the engine is still in good shape. Is that true? Where would I go to get that done?
From: americas finest, calee fourn ya, united states
honda's can run well over 250k deep into the 300k's if maintained well but, with 266,xxx miles you should keep a close eye on it also start looking into getting things internally for the engine to extend the life of the engine. with the correct maintaince and parts you can double your current mileage we all can.
I picked up my 96 Cx with 180k jan. 01-05. I put in an EX cluster and probbaly have close to 187k on the motor. Running strong as ever.
<u>Maintenance done</u>
[*] 2nd oil change coming this week[*] new plugs going in with oil change[*] change out tranny fluid this week[*] New timing belt / water pump[*] distributor cap / rotor button[*] new plug wires[*] coolant has been changed out
I'm going to swap in an LS and keep the D16 for back-up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16delteg »</TD></TR><TR><TD CLASS="quote">just b/c of that guy and his boosted 240k VX...i'm so tempted to boost my high milage b16a3...
b series rods are alot stronger than D series rods.. that B16 is begging to be turbo'ed. if i can do it on a 235K VX.. you can too!
</TD></TR></TABLE>b series rods are alot stronger than D series rods.. that B16 is begging to be turbo'ed. if i can do it on a 235K VX.. you can too!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dzminiz »</TD></TR><TR><TD CLASS="quote">mine had 249,xxx when i bought it. Stock clutch in it too, but had a lil over 250k when she took a **** on me.
on my 97 GSR, the OEM clutch failed finally at 160K. the center part where the splines connect to the disk gave, and had alot of slop. the friction part of the disk was actually ok. the springs and the center gave out. slapped a $100 ebay exedy clutch and its good as gold.
</TD></TR></TABLE>on my 97 GSR, the OEM clutch failed finally at 160K. the center part where the splines connect to the disk gave, and had alot of slop. the friction part of the disk was actually ok. the springs and the center gave out. slapped a $100 ebay exedy clutch and its good as gold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dawrenn »</TD></TR><TR><TD CLASS="quote">My D16Y8 has 95,xxx I do all the basic mantinence but I dont know how long its going to last because I drive it kinda hard. I have probably taken it to redline about 15 times since I bought the car 2 years ago with 69.xxx miles. I want to turbo it but someone told me that my mileage was too high to do so and I dont know if the engine will be able to handle it. What do I need to check to see if it can handle turbo? I heard that I could get a compression and leak test to see if the engine is still in good shape. Is that true? Where would I go to get that done?</TD></TR></TABLE>
LoL... dude, you redlined the car 15 times in two years? I redline my car at least 15 times a week! Haha... and I'm turbo with 105k miles!
Do a compression test and boost that beeotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hackbackb18c1 »</TD></TR><TR><TD CLASS="quote">Do you guys all have the original transmissions?
yea mine has the orginal tranny, but not original clutch of course
just keep up with oil changes and tune ups. You should be good for a long time. I was reading on another site that some people are getting over 400k miles on there civics. Thats just insane. I thought my civic w/ 161k miles on it was a lot. haha
