No Start.
Old Apr 11, 2005 | 05:19 PM
wannarunthateg's Avatar
Default No Start.
I re-installed a '94 gsr motor into my 94 Civic Si Hatch.The motor was hydro-locked and i did a complete rebuild but now the car will not start. I have no fuel coming up from the pump.But when i jump the pump out on the main relay i hear the pump come on and i pump gas up.but when i connect the relay the pump does no come on.I just replaced the relay today and it is doing the same thing.I am stuck.I dont know what to check.The fuel pump is good and the wiring from the relay to the pump is good.Does anyone know what this could be? Your Help Would be greatly appreciated.Thanks.
-Tim
Old Apr 11, 2005 | 05:54 PM
LShatchie's Avatar
Default Re: No Start. (wannarunthateg)
Does the motor just crank and crank but no start ?
Old Apr 11, 2005 | 06:21 PM
Default Re: No Start. (LShatchie)
yeah motor cranks but u can tell ur missing fuel.
Old Apr 11, 2005 | 06:28 PM
LShatchie's Avatar
How can you tell? When I swapped my motor in I thought it wasnt getting fuel, and it ended up being my grounds werent all hooked up.
Old Apr 11, 2005 | 07:09 PM
the pump isnt turning on so i disconnected the main relay and jumped out the pump as per the manual and the pump turned on..what grounds where u missing i will check them.i think i have a grounded wire some where.
Old Apr 12, 2005 | 07:59 AM
LShatchie's Avatar
I was missing the thermostat ground. I thought my car wasnt getting fuel also because of the pump and it really wasnt because I took the fuel rail off after tryin to start and it was bone dry, but it wasnt because the pump wasnt working. I connected the ground, and after a few cranks it started. I cant think of all the grounds but I know there is a thermostat ground,transmission ground, valve cover ground, the battery ground (negative wire to body) and I think one on the intake manifold.
The Destroyer
49
Jul 9, 2010 12:03 PM
ColMustard
Dec 25, 2008 11:23 PM
juanchoenuncrx
Aug 29, 2007 07:59 AM
Unjockable
34
Mar 3, 2004 07:38 AM
-DC2-
Aug 4, 2003 09:58 AM
