Need INFO!!!!!!!
Old Apr 11, 2005 | 04:19 PM
Supa_Slow_Civic's Avatar
Default Need INFO!!!!!!!
Alright hears the deal....I have a BARE LS head....When I say bare I mean bare.....Okay I need some info on what i can use as far as main caps.....I have been told that i could use any LS main caps and everything would be fine....But then again i have been told that you cant use just any LS main caps....I has told that you would have to have the main caps line bored??????So if I pull some mains from the junk yard do i need to have them line bored or will everything be fine??????If you can help me out that would be great.
Old Apr 11, 2005 | 04:50 PM
Simple's Avatar
Default Re: Need INFO!!!!!!! (Supa_Slow_Civic)
you need to use the main caps that come with the head... honda drills them straight through for the cams, so all journals are the same for those cams... but it varies every head.. so if you dont have the main caps from that head... its junk
Old Apr 11, 2005 | 05:00 PM
acefabric's Avatar
Default Re: Need INFO!!!!!!! (Simple)
<FONT COLOR="green">Honda's are not cracked caps right? So you could get some other mains and then go to a machine shop and have them resized and matched and then you would just have to get thicker bearings. Call your local machine shop and ask them if they can do it and how much with new bearings. If they are cracked caps then you s.o.l. but I don't think they would be. I know ford sometimes uses them on their rod's (another reason never to own a ford) but I never really messed with the Honda's internals before. You would have to call a local machine shop and ask them because this seems like a topic that would just keep going round and round. Bearing journals can be resized and cut but remember you will have to get the correct bearings so get them straight through the machine shop so you don't mess up the motor putting in the wrong size ones.</FONT>
Old Apr 12, 2005 | 02:09 PM
Default Re: Need INFO!!!!!!! (dadeboy)
So I might as well junk the head....Bc theres no main caps
Old Apr 12, 2005 | 03:00 PM
DelSol-B-18's Avatar
For what you would pay, to have the new main caps calibrated to ur head, and bearings sized etc. u could pick up a head... Call around.. There a time a dozen..
Old Apr 12, 2005 | 04:13 PM
acefabric's Avatar
I would call and ask, resized bearings are not going to cost more then regular bearings. Just the machine work, But if your building a motor anyways you need machine work done so It might be worth your while. Did you even call a shop and find out how much?
Old Apr 13, 2005 | 02:38 PM
No not yet....But im bout to pick up a full head this weekend so this one i have now isnt worth messing with....Thanks for the info
vteg94
Jun 26, 2007 07:58 PM
integ401
Apr 7, 2007 11:55 PM
C.r.D Integ
Aug 9, 2006 03:58 PM
preludesi93-arg
Jun 28, 2005 07:03 PM
