a newb question on suspension install
Old Apr 11, 2005 | 03:36 PM
duq's Avatar
duq
Default a newb question on suspension install
so I plan on replacing the shocks and springs on my 93hb, but have a question or two. will the shocks and springs that I purchase for my bone stock eg still work in the future if and when I swap the control arms and whatever else that gets swapped out. as u can see, I dont know **** about all the possible swaps, but I really need to lower the car to get it handling a little better. I'm really new to honda (I've been a german car person all my life, yea not sure why) so I will like to get to really understand what can be swapped with what, but at the sametime I cant wait that long to lower my new 93hb. thanks
Old Apr 11, 2005 | 03:40 PM
tur3oDC4's Avatar
Default Re: a newb question on suspension install (duq)
Do you mean can you use your stock suspension after u take it out ..? yes
Old Apr 11, 2005 | 03:41 PM
EK k kay's Avatar
As long as you don't swap in ITR lower control arms then you will have no problems. I don't know of any other rear lower control arms that would change the shock fork type other than the ITR ones.
Old Apr 11, 2005 | 03:43 PM
duq's Avatar
duq
Default Re: a newb question on suspension install (chowmien)
thanks chowmein.. that answered my question
Old Apr 11, 2005 | 03:45 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Yea you will be fine. One thing you might want to consider is getting suspension for a 94+ integra. That way you will have better spring rates if/when you swap the motor.
Old Apr 11, 2005 | 04:51 PM
duq's Avatar
duq
Default Re: a newb question on suspension install (JDM_Ej)
would I need to swap my lower control arm from a 94+ integra to run shocks and springs meant for the integra? sorry for this lame questions, the search feature is not working with me too well
Old Apr 11, 2005 | 04:54 PM
Brodie Bruce's Avatar
pretty much all of the integra components are the same as the civic stuff. So you can just order shocks/springs meant for an integra so you get stiffer rates and it will still bolt up to your car.
Spoonsinglecam
Suspension & Brakes
Nov 8, 2007 01:54 PM
Brown-tec
Apr 25, 2006 05:53 AM
CRAZYEG9
Sep 14, 2004 03:32 AM
GrossmeisterB
Jul 31, 2004 10:56 PM
2000Si-at-UK
Nov 12, 2002 05:09 PM
