Type R OEM Cat question.... :)
Will a 01 type r cat fit my 94 gsr? Besides the extra 02 sensor hole, I just need to know if the flanges line up correctly and bolts on. Thanks for the help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">Will a 01 type r cat fit my 94 gsr? Besides the extra 02 sensor hole, I just need to know if the flanges line up correctly and bolts on. Thanks for the help
It should be a different length. It is a different length than 97+ integras, I think 94-96 are the same.
</TD></TR></TABLE>It should be a different length. It is a different length than 97+ integras, I think 94-96 are the same.
one type r owner measured his and its 17.5 inches just like a gsr one should be for my year. We are just not sure about the flanges.
I do not think it'll will bolt up.
Check out the Comptech website for Header and Exhuast for Integra and you will find that Integra GSR 00-01 and ITR 97-01 have the same Part# for exhaust as well as header.
Integra 94-99 part# is different because of the length of the Cat. and exhaust system.
It may appear that you have to get a header and exhaust system from ITR 97-01 or GSR 00-01 in order for your Cat to bolt right up.
http://www.comptechusa.com/store/integra.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr »</TD></TR><TR><TD CLASS="quote">ok so now the question is. will a usdm itr header + cat + gsr exhaust bolt up? </TD></TR></TABLE>
Not unless the GS-R exhaust is a '00 or '01.
ek82
Oct 15, 2007 05:07 PM
