395whp on stock internal gsr @ 12psi and pump gas
Old Apr 11, 2005 | 02:02 PM
joepiscapo_83's Avatar
Default 395whp on stock internal gsr @ 12psi and pump gas
went to the dyno today and i am very impressed with the numbers for a bone stock gsr block. 395whp and 262 torque @ 12psi and pump gas.
setup: bone stock gsr block, b16a head w/ gsr cams, t3/t67 .82 a/r, lovefab sst manifold, 3" exhaust and downpipe, walbro 255hp pump, 880cc precision injectors, aem ems, etc., etc., etc.....
what do you guys think for a stock 200 dollar block slapped in???
Modified by v8killr83 at 1:28 PM 4/12/2005
Old Apr 11, 2005 | 02:06 PM
batboyvaj's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (v8killr83)
WOW....
non-VTEC's Avatar
thats allot of power for a stock GSR engine........good stuff but i would be worried about the reliabilitly.........
how long do you expect those pistons and rods to hold up?
Old Apr 11, 2005 | 02:15 PM
tthame1's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (non-VTEC)
Sick power for such low boost I am hoping for that power at 15+psi.
Old Apr 11, 2005 | 02:22 PM
chidoks's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (batboyvaj)
nice numbers...
Old Apr 11, 2005 | 02:30 PM
dustin's Avatar
post your ignition map
Old Apr 11, 2005 | 02:36 PM
95GSRT's Avatar
That's sick
Old Apr 11, 2005 | 02:52 PM
oh yea...i forgot to add that i am building the eng this week. i will be sticking with stock sleeves, just upgrading rods and pistons. 81.5mm bore should do it. i am shooting for 500whp on stock sleeves next time on the dyno....
also for timing....i was at 19 degrees at 12psi boost. pretty conservative but i was pushing it pretty hard i think....lol!!!
Old Apr 11, 2005 | 04:32 PM
11psiTurboSI's Avatar
Nice #'s
Old Apr 11, 2005 | 04:46 PM
turbosi03's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (11psiTurboSI)
god dam man! I'm shooting for a little more then that on a fully built motor
definately let us know when it goes, or if you rebuild it before it does...
Old Apr 11, 2005 | 04:47 PM
integlspwr2k's Avatar
damn thats some very good numbers for 12psi. Hopefully i can achieve 350whp on a fully stock b16.
Old Apr 11, 2005 | 06:04 PM
mdpalmer's Avatar
Sounds pretty mean. @ what RPM do you get full spool? The turbo (0.82 A/R) would seem to me to be a bit laggy
Old Apr 11, 2005 | 06:16 PM
adseguy's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (mdpalmer)
19 degrees at 12 PSI isn't too conservative....I've seen people run 11 degrees at 15 PSI trying to do the same you were. GL and drive her hard so we can see if it'll hold up
Old Apr 11, 2005 | 07:14 PM
nonvtecD's Avatar
Insane numbers for stock block
Old Apr 11, 2005 | 07:22 PM
2point2's Avatar
it's a good start!
https://honda-tech.com/zerothread?id=1171997
Old Apr 11, 2005 | 07:26 PM
racinskittle's Avatar
Default Re: (2point2)
WOW............that is one nice setup. Very well done.
That GSR block/B16 head combo looks like it works damn good...
Old Apr 11, 2005 | 09:07 PM
its only a 1.8L. you cant really compare my setup to a prelude man...come on...lol!!! plus you were at 18psi. let me turn the boost up then well talk....jk!
thanks everyone for the props!!!
Old Apr 11, 2005 | 09:16 PM
DFW's Avatar
DFW
Default Re: (v8killr83)
damn thats some good #'s for stock block and head on 12psi.
keep us updated on it. oh yeah, is it a daily driver?
Old Apr 12, 2005 | 07:58 AM
quicksol95's Avatar
Default Re: (DFW)
sick
Old Apr 12, 2005 | 08:01 AM
SOHC_MShue's Avatar
damn those numbers are insane for a stock motor
Old Apr 12, 2005 | 08:13 AM
YiNYaNg's Avatar
Old Apr 12, 2005 | 09:22 AM
D-tuned's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (H-T)
those are some sick numbers for a stock sleeves. Nice job.
Old Apr 12, 2005 | 09:31 AM
darkdayz's Avatar
good job....but I'd keep my eyes on that beast
Old Apr 12, 2005 | 09:41 AM
TurboJesse
Guest
Posts: n/a
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (2000civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000civicsi &raquo;</TD></TR><TR><TD CLASS="quote">those are some sick numbers for a stock sleeves. Nice job. </TD></TR></TABLE>
Stock sleeves????? Those would be the last of my worries ~400whp...what about stock pistons?
Either way nice job. Im all about stock blocks
Old Apr 12, 2005 | 10:45 AM
tgreaves's Avatar
Default Re: 395whp on stock internal gsr @ 12psi and pump gas (integlspwr2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">damn thats some very good numbers for 12psi. Hopefully i can achieve 350whp on a fully stock b16.</TD></TR></TABLE>
Looks like we are both looking for the same thing here..
