Ignition problem No Spark please help.
just installed my b18c gsr motor in my 92 eg. Ran the car then I decided to change my spark plugs. Bought new ones, put them in, car started then died about 15 seconds after I started it. I changed the Rotor and distributor cap, still wouldnt start. Changed ignition coil then it started up for a few seconds, then died again, wouldnt start anymore. Any Idea?
I wonder if you have a clog in your fuel system or injectors. I would check there first because if it started you got some type of spark..Right?
Anyway, I am a little clueless on this, but here is something that can help you check off problems, if it is not a fuel system thing.
Try this flow chart at http://www.nutzandboltz.org
The more specific link is.
http://www.nutzandboltz.org/Se...t.pdf
You need Adobe to read this because it is a PDF file.
Ignore the information about the switches at first so you can check all your possible problems.
Good luck.
Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RomoGuy »</TD></TR><TR><TD CLASS="quote">btw I did NOT gap the plugs, the car did run before I changed the new plugs</TD></TR></TABLE>
And what happens when you throw the old plugs back in? Check your ICM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapwr »</TD></TR><TR><TD CLASS="quote">And what happens when you throw the old plugs back in? Check your ICM.</TD></TR></TABLE>
a lot of the time, it end up being the fuel stuff
