Need help wiring mini me swap!
Old Apr 11, 2005 | 11:41 AM
jeff13's Avatar
Default Need help wiring mini me swap!
I need to know what i need to do to get my car running. I have a d15b2 block (dpfi) and i have a d16z6 head. I have a pm6 ecu and a apexi vafc and i have been told that i can just use that to wire up vtec, but What do i need to do to get this running? pull harnesses or what. let me know thanks, ive been pondering this for about a month now and dont know what to do. I appreciate the help.
Old Apr 11, 2005 | 11:52 AM
Rywire's Avatar
Default Re: Need help wiring mini me swap! (jeff13)
Your best bet is to run obd1 and the p28 ecu.
We offer this swap on http://www.rywire.com - http://www.rywire.com/dxtodvtec.shtml
Ryan
Old Apr 11, 2005 | 07:21 PM
jeff13's Avatar
Default Re: Need help wiring mini me swap! (droppedcrxsi)
i would have done that if i didnt get rid of my p28, but im not spending 400 bucks on this when there is another way to do it. Thanks for the input, anybody else.
Old Apr 11, 2005 | 08:22 PM
Rywire's Avatar
You can also activate vtec with a switch.
Old Apr 11, 2005 | 08:41 PM
lodo1's Avatar
first thing to do would be to convert to mpfi. its super simple to do, that way your pm6 will run everything smoothly, then you will hook up the vafc to the vtec solenoid to activate vtec.
which intake manifold are you using?
Old Apr 11, 2005 | 09:20 PM
Jeff's Avatar
Banned
My friend has the mini me setup yet doesn't want to do it by switch. He is thinking of wiring it to a tach with a shift light. Is that possible or is there an easier solution. He wants it to kick in by itself so he doesn't have to use a switch
Old Apr 11, 2005 | 10:18 PM
lodo1's Avatar
Default Re: (Jeff)
yes, you can ghetto rig it to a tach with shift light. its just a wire that needs to see current at a specific time to turn on the vtec solenoid
Old Apr 12, 2005 | 11:50 AM
jeff13's Avatar
I am using a z6 intake manifold, is that going to be a problem?
Old Apr 12, 2005 | 12:05 PM
menappi's Avatar
sell the vafc and get a p28 and use the extra money to get something useful. if u did a search you would find hundreds of mini me threads outlining the wiring.
Old Apr 12, 2005 | 01:17 PM
Servo's Avatar
Default Re: (Jeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff &raquo;</TD></TR><TR><TD CLASS="quote">My friend has the mini me setup yet doesn't want to do it by switch. He is thinking of wiring it to a tach with a shift light. Is that possible or is there an easier solution. He wants it to kick in by itself so he doesn't have to use a switch</TD></TR></TABLE>
He shouldn't use an 'actual' switch. He needs an RPM switch. It reads the car's RPM signal and shows power above a predefined RPM point.
FWIW, RPM switched VTEC will do no good without fuel/timing tuning to extract more power out of the larger cam lobes.
Old Apr 12, 2005 | 07:18 PM
jeff13's Avatar
Default Re: (Servo)
i need the vafc cause i got a crower stage 2 cam and 360cc injectors. anybody else? i love the advice guys, i didnt get one reply on superhondar .com
Old Apr 14, 2005 | 11:53 AM
jeff13's Avatar
anybody else?
Old Apr 28, 2005 | 05:20 PM
EDVxRICHARD's Avatar
Default Re: (menappi)
im planin to do the same thing too because my gasket is worn and needs to change and i might as well get a sohc vtec head to add a little more power.......will the p28 help the vtec engage without the switch or tach?.........and if this is said in one of the other topic then will you give me the site to get there.....
hondajav06
15
Oct 28, 2010 05:25 PM
slammedhatch13
Dec 5, 2005 08:04 PM
Dirtfall
Sep 3, 2005 01:46 PM
JDMHatch101
Dec 23, 2003 05:47 AM
spoonvtec101
Aug 11, 2003 08:34 PM
