type s oversized or standard pistons with 100xxx miles on lude
Old Apr 11, 2005 | 11:36 AM
luap's Avatar
Default type s oversized or standard pistons with 100xxx miles on lude
which pistons would u guys recommend if i got alot of mileage?
Old Apr 11, 2005 | 11:38 AM
94vtecmn's Avatar
Default Re: type s oversized or standard pistons with 100xxx miles on lude (luap)
I went with the type-s oversized, 144,xxx miles at the time. Get a new bore an hone job per FRM specs, and you'll be like new again.
Old Apr 11, 2005 | 01:06 PM
luap's Avatar
Default Re: type s oversized or standard pistons with 100xxx miles on lude (94vtecmn)
how much did all that cost you???
Old Apr 11, 2005 | 01:27 PM
94vtecmn's Avatar
Well that's not all that I did. I did a total rebuild, including some Crower stage II cams, springs, retainers, new rods (You need to use different rods for the Type-S pistons in a 93-96 VTEC motor), balanced crank with new bearings, etc., etc. I think with the VTEC controller, installation, and dyno time, I have about $3000 into it. The only thing I'd like to have is an SMSP header on top of what I have.
Old Apr 11, 2005 | 01:55 PM
Rad Racing's Avatar
Bart Taylor Look-alike
It's worth it to rebuild a H22 with type S pistons. Definatley go OS. It will cost you about $500 maybe a bit more depending on your location to have the block honed, crank balanced, etc. and assembly of the new pistons/rods. Type S pistons with rings go for about $300-350.
If you want brand new OEM rods, that will be another few hundred or if you find used ones you can get them balanced from the engine builder/machinist. Make sure you take it to someone who knows what they're doing, they'll tell you exactly what they need to do to make it work.
Old Apr 21, 2005 | 08:40 PM
luap's Avatar
Default Re: type s oversized or standard pistons with 100xxx miles on lude (Rad Racing)
when i go with os pistons wouldnt i have to bore .25 more?
Old Apr 22, 2005 | 08:14 AM
Keewun's Avatar
i have a question. So if you put type S piston on them 93-96 year motor. you need new rods too? and what kind?
Mastgohn
May 2, 2013 08:14 AM
DELSLOWEST
Oct 1, 2004 11:19 AM
ls95hatch
Jun 25, 2004 11:20 AM
c1civic
Feb 13, 2004 09:01 PM
