crower in with skunk2 ex
I'm pretty sure you can, but the gains won't be compairable - because the lift/duration overlapping is designed to work a certain way.....now, if you get an obx stage II intake cam with a skunk2 stage II exhaust cam - it will work perfectly....because OBX cams are the exact same as the Skunk2 cams as far as the lift/duration goes.
topdog
13
Nov 21, 2003 03:09 PM
