D16y8 swap with an 88 Si Transmission
I keep reading that 89 and up there really is no problem, what about us 88 guys? I just blew my A6 and am looking at a Y8 replacement. I would love to reuse my new clutch and trans.
Any problems here?
TIA
Any problems here?
TIA
You need to use the 88 flywheel, clutch, and transmission. A little rule of thumb is to match the clutch and flywheel to the transmission.
88 are the balck sheep of the bunch....the 88 tranny and a 21 spline shaft compared to the 90-91 wich is a 20 spline...as for the 89 i'm not to sure it been 20 or 21...
i think u can transfer the flywheel, clutch and plate over to ur new y8 block...
i have a z6 blocj mated to a jdm zc tranny with a z6 flywheel clutch..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">You need to use the 88 flywheel, clutch, and transmission. A little rule of thumb is to match the clutch and flywheel to the transmission.</TD></TR></TABLE>
what he said
what he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AZTEKEF9 »</TD></TR><TR><TD CLASS="quote">88 are the balck sheep of the bunch....the 88 tranny and a 21 spline shaft compared to the 90-91 wich is a 20 spline...as for the 89 i'm not to sure it been 20 or 21...</TD></TR></TABLE>
The '89 Si transmission did have 20 splines, just like the '90-'91 Si's. However, the '89 had a smaller clutch and flywheel than the '90-'91s.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mach69 »</TD></TR><TR><TD CLASS="quote">
The '89 Si transmission did have 20 splines, just like the '90-'91 Si's. However, the '89 had a smaller clutch and flywheel than the '90-'91s.</TD></TR></TABLE>
Yup it is like the 88 is the black sheep while the 89 is the gray sheep.
justin-95si
Dec 10, 2012 12:08 AM
99sonicbluegsr
Mar 21, 2005 12:15 PM
nuc79
Feb 1, 2004 08:21 PM
