turn signals not working and a buzzing
Old Apr 10, 2005 | 09:28 PM
folta2169's Avatar
Default turn signals not working and a buzzing
ok today i was driving around at nite and i relized that sometimes my gage lights are really dim or just not working for the needles and sometime it would change and be fine and when it would be fine, when i turned the right turn signal everything(dash lights and head lights) pulsed with the turn signal but on the other hand the left turn signal would be fine. then all of a sudden my signals stopped working all together and when i turn the key on to start my car there is a buzzing noise sound comming from the das somewhere to the left of the steering wheel........what could this be. also my v-tec isn't working and one vacume line isn't hooked up.
Old Apr 10, 2005 | 10:22 PM
TIRENECK's Avatar
Default Re: turn signals not working and a buzzing (folta2169)
u people really need to start fixing open wires when u see one. What I would do before you start checking fuses is to check out all the plugs for the headlights, turn signals and stop lights for any that might be touching ground. If all looks good there follow the wire harness going to the turn signal switch (the thing u move) and follow the wiring and check all ur grounds.
Old Apr 10, 2005 | 10:55 PM
92integra_gs's Avatar
sounds like your positive and negative is touching which means its shorting out... you need to get that wiring fix...
Old Apr 11, 2005 | 09:47 AM
folta2169's Avatar
Default Re: (92integra_gs)
ok well if something was touching/shorting out wouldn't a fuse has blown.
Old Apr 11, 2005 | 10:40 AM
CPT.PANDA's Avatar
same thing happemd to me about the buzzing . i checked everything. turns out it was the relay. so i just took it out of my hatch.
hybridnorth
37
Feb 16, 2019 06:13 AM
Jay Millstone
Sep 8, 2018 09:49 AM
corps
Feb 1, 2011 12:13 PM
acurar
Jun 10, 2010 07:18 AM
