H23 Tranny swap auto to 5spd: What do you guys think?
So im looking to get rid of the automatic. I guess does any one have any write ups or how tos and what parts are needed for it? Or should i go and do the whole h22a1 and tranny swap and write up and what not for that. Thanks
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luderollin »</TD></TR><TR><TD CLASS="quote"> what parts are needed for it? Or should i go and do the whole h22a1 and tranny swap?. Thanks</TD></TR></TABLE>
it depends on how much money you got, as far as simplicity the h22-transmission combo is a good choice, just make sure it comes with everything for the swap.
I guess does any one have any write ups or how and what parts are needed for it? Thanks</TD></TR></TABLE>
as far as info on this type of swap, if you do a search you will be 99.5% closer to finding the answer you want to hear.
but this will be a start---http://www.mazmo.com/zameoj/swap.htm
I did the swap about 3 years ago on my prelude. Yes, it is labor intensive - took about 18 hours of straight work for 2 people. We took an engine/tranny from a wrecked parts car. It is easiest to do the swap if you have a parts car to take all the parts (including clutch line, bolts, pedal assemblies, etc.) from. Otherwise, you would drive yourself crazy!
Hey Luder 94si , im doin this swap in a couple of months. I need the 5spd brake pedal assembly correct? Is this just straight foward unbolt the auto brake pedal assembly and bolt in the 5spd brake pedal assembly? Thanks
steve
steve
