ZC.. quick answer please
Friend has a ZC hatch... got a TDC code the other day
he needs to get a new distributor, but hes wondering what to get? one from a ZC, maybe a SI one?
A 90-91 CRX Si dizzy is a 7 pin dizzy that has the CPS Sensor built into it.. A ZC Dizzy should be a 5 pin dizzy with a CPS Sensor on the Exhaust cam. I think you can use an 88-89 Si dizzy though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StupidSlowCRX »</TD></TR><TR><TD CLASS="quote">A 90-91 CRX Si dizzy is a 7 pin dizzy that has the CPS Sensor built into it.. A ZC Dizzy should be a 5 pin dizzy with a CPS Sensor on the Exhaust cam. I think you can use an 88-89 Si dizzy though
umm you need one off a 89 integra... i just had to buy one for my CRX. the cap will need do be modded to fit. But i think its one off a 91 Si
</TD></TR></TABLE>umm you need one off a 89 integra... i just had to buy one for my CRX. the cap will need do be modded to fit. But i think its one off a 91 Si
Its the 88-89 integra d16a1 distributor for sure that you need. They are known for going. The cap is the same as the 88-91 SI, but should be included if you buy a new distributor anyway.
-[sphEre]-
13
Oct 14, 2004 08:08 PM
