Are DA axles a 'perfect fit' for b16 CRX?
Old Apr 10, 2005 | 05:06 PM
Kusai.Nihonjin.Desu's Avatar
Default Are DA axles a 'perfect fit' for b16 CRX?
Are DA axles too long? I've read that people use these axles without a problem...my swap is an XSi swap (b16/ys1). Thanks.
Old Apr 10, 2005 | 05:30 PM
SiR Inspired ED7's Avatar
Default Re: Are DA axles a 'perfect fit' for b16 CRX? (Nihonjin)
THEY FIT
(90-93 DA's)
Old Apr 10, 2005 | 05:59 PM
crxgator's Avatar
you have to take off the dust ring on the back of the knuckle though...
Old Apr 10, 2005 | 06:25 PM
Jester88Si's Avatar
unless u use da knuckles
Old Apr 11, 2005 | 02:16 PM
camo_crx's Avatar
i had ls hubs and spindles with ls axles. now i have 99-00 si axles they work fine so far
Old Apr 11, 2005 | 02:59 PM
thatbluecrx's Avatar
Default Re: (camo_crx)
i had problems using 90-93 teg axles in my b16 crx... but i didnt know about the dust ring part at the time..
passenger side fits fine but the driver was slightly off and would vibrate like a motha
Old Apr 11, 2005 | 03:01 PM
daidilus's Avatar
they work well if you use a 90-93 imtermediate shaft
Old Apr 11, 2005 | 03:24 PM
Default Re: (daidilus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daidilus &raquo;</TD></TR><TR><TD CLASS="quote">they work well if you use a 90-93 imtermediate shaft</TD></TR></TABLE>
YS1 intermediate shaft should be the same as a 90-93 int shaft, right? i cant imagine XSi's in japan using different int shafts. that's what came with my motor.
im going to pick up a set of 90-93 axles tomorrow.
the thing is, i have a 92 GSR, and those axles didnt work for my XSi swap for the crx. im wondering if ABS has a factor? i noticed places sell different sets of axles for ABS and non-ABS.
Old Apr 11, 2005 | 04:01 PM
crix351c's Avatar
DA KNUCKLES
Old Jun 23, 2009 | 12:49 PM
exist12's Avatar
PERFECT FIT. Just take off the Inner Dust Rings on the Knuckles. Dont worry about intermediate shaft.
Old Jun 23, 2009 | 12:51 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Yes.
Old Jun 23, 2009 | 04:53 PM
lunalink's Avatar
will the EK axles fit on the rex?i got my swap off a 2000 Si.b16a2..wil they fir or do i need DA axles?(i know about the dust ring
Old Jun 23, 2009 | 05:40 PM
Crx Jimmy's Avatar
you can use da or ek axles you just need the matching mid shaft. if using the 99 si midshaft you have to put a 99si seal on that side of the tranny as that shaft is a different diameter . thats what I am using right now, abs and non abs does not matter, as well as auto or manual axles they all fit the same.
Old Jun 23, 2009 | 05:45 PM
lunalink's Avatar
o.k kool.. thats one less thing to worry about when i get ready to swap in my motor..
.Grimace
Sep 23, 2005 12:38 AM
90hbvtec
Dec 11, 2003 06:08 PM
b18crx
May 26, 2003 06:28 PM
XANDER-666
Oct 7, 2002 12:04 PM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
